		| Author | Message |
		| tavioman
				| Map pins into a struct. |
				|  Posted: Mon Sep 24, 2007 2:22 am |   |
				| Hi everyone. I have a small question.
 I need to make an array of structs.
  	  | Code: |  	  | MY_STRUCT_TYPE array_of_structs[2];
  	  | Code: |  	  | typedef struct {
 UNSIGNED_8 member_1;
 UNSIGNED_16 member_2;
 A PIN FROM A PORT the_pin;
 MY_STRUCT_TYPE;
 I have an init function where I will set up some initial values of both structs.
 But how can I set-up in one struct to have access to a pin to have something like this:
  	  | Code: |  	  | void DoSomething(UNSIGNED_8 index) {
 MY_STRUCT_TYPE* pointer;
 pointer = &array_of_structs[index];
 if(pointer->the_pin == TRUE)
 printf("Pin is High\r\n");
 Is this possible?
 Thank you.
		| Ttelmah Guest
				|  Posted: Mon Sep 24, 2007 4:02 am |   |
				| First question, what compiler version?. If you are using a V4 compiler, then the 'pin numbers' for functions like input_pin, can be variables. So you can have:
 int16 the_pin;
 MY_STRUCT_TYPE;
 //Then with the array declared define the pins using something like:
 array_of_structs[0].the_pin=PIN_B0;
 array_of_structs[1].the_pin=PIN_B1;
 //etc.
 //Which can then be accessed, with:
 if (input(pointer->the_pin))
 The same basic construction, can be used in older compilers, by 'emulating' the variable based functions. Code for this has been published here in the past. A search for the keyword 'procedures', should fid the version published by PCM_programmer to do this.
 You can 'map' a variable directly 'onto' a port, or bit, but you can't do this for a single pin inside a structure.
		| tavioman
				|  Posted: Mon Sep 24, 2007 4:42 am |   |
				| Thanks! I will try your solution.
