Watch Dog Timer (wdt), 12F683 nanowatt prescalar setting
Posted: Thu Jul 21, 2005 10:16 am
Just started playing with the watch dog timer on the 12F683. Data sheet says the time out can be set between 1ms and 268 seconds. Is this a typo? Has anyone ever used such a long time out in a product? Is WDTCON the only register needed to be modified or is there something else?
languer
Posted: Thu Jul 21, 2005 1:11 pm
Never used this feature on the chip, but after reading the datasheet it should be possible.
Referring to Figure 12-9. The WDT will use the LFINTOSC (31kHz) as reference. From there it goes through a 16-bit Prescaler (÷32 through ÷65536), and can further be routed through a 7-bit prescaler (÷1 through ÷128) shared with TMR0 (8-bit if used for TMR0). So you could have a maximum divisor of 8388608 (23-bit) - pretty nifty.
Registers used (all summarized in Table 12-8):
WDTCON.7-0
OPTION.3-0 -> PSA, PS2, PS1, PS0
CONFIG.3
