error float decimal with sin() cos()
T0ni0
PostPosted: Wed Jul 20, 2005 10:14 am     Reply with quote
Hi i need do this formule:
return &acos(cos($a1)*cos($b1)*cos($a2)*cos($b2) + cos($a1)*sin($b1)*cos($a2)*sin($b2) + sin($a1)*sin($a2)) * $r;
but i look error at 7 decimal of float after make sin() and cos() ¿?
i need accurasy calcul, but i compare with a calculator and i look bad results at c5,c6,c7
PIC 18F6720
PCH 3.227
      dlong=6378;               //radio tierra
      c1=latitud * degtorad;      //a1
      c2=longitud * degtorad;      //b1
      c3=arealat * degtorad;      //a2
      c4=arealong * degtorad;      //b2
      c5= cos(c1)*cos(c2)*cos(c3)*cos(c4);
      c6= cos(c1)*sin(c2)* cos(c3)*sin(c4);
      c7= sin(c1)*sin(c3);
      distan = c5+c6+c7;
      distan = acos(distan);
      distan = distan * dlong;
Thx for advance, and sorry for my bad explanation in english
PostPosted: Wed Jul 20, 2005 11:08 am     Reply with quote
Here's a web page that discusses Microchip floating point.
http://www.bknd.com/cc5x/math.shtml
It says:
Format    Resolution
32 bit    7.2 digits
The floating point format used by CCS doesn't have as much
resolution as the format used by MSVC++.
SherpaDoug
PostPosted: Wed Jul 20, 2005 11:32 am     Reply with quote
As a general principle, if you want accuracy stay away from floating point!
carlosma
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Wed Jul 20, 2005 4:54 pm     Reply with quote
Hello
already I had a problem as this, when I had to calculate tan() and acos(). I decided with the following Post:
[url]
http://www.ccsinfo.com/forum/viewtopic.php?t=22405&highlight=
[/url]
important to simple mathematics expression
more RAM and later 18F452.
Do you use this for a Solar tracking?
T0ni0
PostPosted: Thu Jul 21, 2005 12:45 am     Reply with quote
Thx, but i need make Sin() Cos() radian, how i can do without float?
PostPosted: Thu Jul 21, 2005 3:47 am     Reply with quote
Unfortunately, you can't. This however does not mean you have to use the standard library.
In the past with a similar problem, I decided that I needed accuracy for a full circle, to a resolution of 1 part in 129600000 (1/100th arc second). I therefore used an int32, and had this 'step' in these units. I then wrote a sin, function, which used first a look-up table to find the 'result' for values at intervals of 36000 points, then used successive approximation to get the required values in between. The result in my case was stored in a signed int32, and scaled so that it counted in 1E-9 units. This gave effectively 9DP accuracy.
There are then two answers. Write your own maths library for the functions you require, or possibly work out if the existing accuracy is good enough (it is common to find that you can get better effective accuracy, by altering the order in which arithmetic steps are performed, and it is important to realise that few mechanical processes even approach this level of accuracy in reality...).
