kender
Joined: 09 Aug 2004 Posts: 768 Location: Silicon Valley
problems with non-debug executable |
Posted: Mon Jul 18, 2005 10:37 pm |
Colleagues,
I have problems building the firmware, which runs without debugger. The hex file does download, but it doesn't run, when I remove the debugger and cycle the power on the box. Here's my h-file. What am I doing wrong?
// version 0.3
#include <18F6720.h>
//#device ICD=TRUE
#device adc=10
#use delay(clock=11000000)
// debug fuses
// #fuses NOWDT,WDT128,HS, NOPROTECT, NOOSCSEN, BROWNOUT, BORV25, NOPUT, NOCPD, STVREN, DEBUG, NOLVP, NOWRT, NOCPB, NOEBTRB, NOEBTR, NOWRTD, NOWRTC, NOWRTB
// release fuses
#fuses NOWDT,WDT128,HS, NOPROTECT, NOOSCSEN, BROWNOUT, BORV25, NOPUT, NOCPD, STVREN, NODEBUG, NOLVP, NOWRT, NOCPB, NOEBTRB, NOEBTR, NOWRTD, NOWRTC, NOWRTB
//#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8, errors)
// CCS supports multiple RS232 streams, and it comes handy during debugging.
// e.g. fprintf(debug_stream, "0x%2X\n\r", read_iso_buttons());
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors,stream=rs232_stream)
#use rs232(DEBUGGER, stream=debug_stream)
#use i2c(Master,Slow,sda=PIN_C4,scl=PIN_C3)
Thanks,
Nick |
Posted: Mon Jul 18, 2005 11:01 pm |
What programmer and what programming software are you using ? |
kender
Posted: Mon Jul 18, 2005 11:27 pm |
I'm using:
ICD-U40 w/ firmware v01.30
ICD control program v2.12
CCS compiler v3.209 |
Posted: Mon Jul 18, 2005 11:42 pm |
But what are you using as an IDE to run the compiler ?
PCW or PCWH ?
or MPLAB 7.20 ?
or the PICC icon ? |
kender
Posted: Tue Jul 19, 2005 12:01 am |
I'm using PCWH for IDE. |
Posted: Tue Jul 19, 2005 12:34 am |
I don't have that IDE so I can only be of limited help, but the line
below is intended for use with the CCS debugger. It creates a
software UART to transmit serial data on pin B3. If you're not
using the debugger, it should probably be commented out.
Code: | #use rs232(DEBUGGER, stream=debug_stream) |
kender
Posted: Tue Jul 19, 2005 11:16 am |
PCM programmer wrote: | ...If you're not
Thank you! After I have masked this line with #ifdef, the code began to work standalone. |
