can't get correct rs232 data?
williamho
PostPosted: Mon Jul 18, 2005 4:34 am     Reply with quote
Hi, I am not sure what goes wrong.
I printf("12,m") from one pic to another pic (below) via RS232.
If I use strcpy(cc,"12,m"):
LCD will show "12" with
printf(lcd_putc,"%s",ptr);
If I use strcpy(cc,&c2)
I cannot get the same data for char ptr
but lcd show "12,m" with
printf(lcd_putc,"%s",cc);
why?
can anyone help?
#include <18F458.h>
#DEVICE ICD=TRUE
#use rs232(baud=9600,  parity=N, Bits=8, xmit=PIN_C6, rcv=PIN_C7)
#include <lcd.c>
#include <string.h>
void main ()
   char *c;
   char cc[10];
   char term[3];
   char *ptr;
   lcd_init();
   lcd_putc("\fready");
   strcpy(term,",");
      if(kbhit()){
         if(i==0)c=getc();i++;
         strcpy(cc,&c);
                                                //strcpy(cc,"12,m"); this is ok
         ptr=strtok(cc,term);
                                                //printf(lcd_putc,"%s",cc)lcd show "12,m"
[/code]
Mark
PostPosted: Mon Jul 18, 2005 5:50 am     Reply with quote
You declared C as a pointer. It shouldn't be.
Looks like you are processing each byte so I am not sure why you are even using strtok() function.
I don't believe this is a complete test program since I see no declaration for i
williamho
PostPosted: Mon Jul 18, 2005 5:57 am     Reply with quote
Hi, Mark.
int i is not use.
I try to search from other posts, but can't solve my prolem.
can it be the kbhit()? or program fall out of the loop?
I try to sort the string 'm' and '12' for future usage.
Thanks.
#include <18F458.h>
#DEVICE ICD=TRUE
#include <lcd.c>
#include <string.h>
void main ()
   char *c;
   char cc[10];
   char term[3];
   char *ptr;
   lcd_init();
   strcpy(term,",");
      if(kbhit()){
         c=getc();
         strcpy(cc,&c);
Mark
PostPosted: Mon Jul 18, 2005 6:03 am     Reply with quote
You are not waiting until you receive the whole string. Instead, you process each byte as it comes in. Take a look at the getstring() function in input.c You need to read the entire string and then process it.
williamho
get_string() no feedback
PostPosted: Mon Jul 18, 2005 7:05 am     Reply with quote
I change my code using get_string() with input.c but get no feedback.
seem that program hanging in input.c when i stop debug.
From master:
i tried put('u'), printf("U"), even printf("%s",string) where string[10]="u"
Why?
#include <18F458.h>
#DEVICE ICD=TRUE
#include <lcd.c>
#include <input.c>
void main ()
    char cc[10];
    lcd_init();
      if(kbhit()){
         get_string(cc,10);
PostPosted: Mon Jul 18, 2005 7:34 am     Reply with quote
Which data sequence are you sending to the PIC in your latest program? Get_string will wait until it receives a carriage return character (0x0D).
Mark
PostPosted: Mon Jul 18, 2005 10:51 am     Reply with quote
Just to add a bit:
You will have to send the CR. Here are some samples:
printf("12,m\r",string)
printf("u\r",string)
printf("%s\r",string)
williamho
thanks
PostPosted: Mon Jul 18, 2005 10:42 pm     Reply with quote
thanks
