rs232 controlling and 16f877 output problem
capella
PostPosted: Sat Feb 07, 2009 6:38 am     Reply with quote
Hello, my problem is that rs232 and pic16f877 communication problem. I want to give 16f877 rb0 or rb1 outputs from pc's keyboard. For example when I wanted to press keyboard, I want to take voltage that pic 16f877 from RB0 output.
Please help me...
source code
#include <16F877.h>
#device adc=8
#FUSES XT                       //Crystal osc <= 4mhz
#FUSES NOPUT                    //No Power Up Timer
#FUSES PROTECT                  //Code protected from reads
#byte port_b = 6
   int data;
   set_tris_b( 0x00 );
   output_B(0x00);//portb çıkış
   printf("calisiyor…\n\r");
   while (TRUE)
     data = getch();
     port_b = data;    //gönderilen sayıyı portb de göster
     if(data=="1") output_high(PIN_B0);
     if(data=="2") output_high(PIN_B1);
     if(data=="3") output_high(PIN_B2);
     if(data=="4") output_high(PIN_B3);
     if(data=="5") output_high(PIN_B4);
     if(data=="6") output_high(PIN_B5);
     if(data=="7") output_high(PIN_B6);
PostPosted: Sat Feb 07, 2009 10:30 am     Reply with quote
Before doing anything else, add series resistors between the PIC pins, and the LEDs. At present, every port Bpin that goes high, will result in overloading the pin (and probably the LED)...
Then, do you want to output the bit pattern comming from the serial as a whole to port B?. If so the retain the line "port_b = data;". Otherwise get rid of this.
In any event, you don't want this line, and the separate lines accessing the port for the different values as well.
You might want to translate the 'comment' on this line.
nicotec
PostPosted: Sat Feb 07, 2009 11:50 am     Reply with quote
Hi, to avoid too external capacitor I suggest You to use MAX233 which need only 10uF capaciton on between VDD and ground.
Regards
capella
PostPosted: Sat Feb 07, 2009 2:08 pm     Reply with quote
Hi, thanks for your answers.
Actually, my problem is that the code doesn't work. I am not good at pic c. My intent is to type a number 0-9 from my pc keyboard, and then one of led will be light. In more details, when I press 1 on the keyboard, the only 1st led will be on, and when it is 2, then only second led will be on.. and so on. On Proteus, I used virtual terminal as serial port.
Can you help me how to change or write the correct codes to make it work?
