micman Guest
optimizing |
Posted: Fri May 07, 2004 2:54 am |
I've a problem with memory full, i help do optimizing the code:
I''ve a structure
Code: | struct sgara {
int8 day;
int8 months;
int8 hours;
int8 minutes;
int8 seconds;
int16 years;
int16 vole;
int8 F_I;
int8 mt;
int16 p_mt90;
int16 p_mt70;
int16 p_mt50;
int16 p_mt30;
int16 p_parz;
int16 p_tot;
int8 flag_Rit;
int8 flag_Buz;
I must save the structure in eeprom internal 18f452
I write the function that it supplies to make it, but it occupies much memory.
Do I optimize this function?:
Code: | void write_eep_struct(struct sgara *gara){
write_eeprom(1, gara->day);
write_eeprom(2, gara->months);
write_eeprom_16(3,4, gara->years);
write_eeprom(5, gara->hours);
write_eeprom(6, gara->minutes);
write_eeprom(7, gara->seconds);
write_eeprom_16(8,9, gara->vole);
write_eeprom(10, gara->F_I);
write_eeprom(11, gara->mt);
write_eeprom_16(12,13, gara->p_mt90);
write_eeprom_16(14,15, gara->p_mt70);
write_eeprom_16(16,17, gara->p_mt50);
write_eeprom_16(18,19, gara->p_mt30);
write_eeprom_16(20,21, gara->p_parz);
write_eeprom_16(22,23, gara->p_tot);
write_eeprom(24, gara->flag_Rit);
write_eeprom(25, gara->flag_Buz);
and read:
Code: | void read_eep_blackout(struct sgara *gara){
gara->day = read_eeprom(1);
gara->months = read_eeprom(2);
gara->years = read_eeprom_16(3,4);
gara->hours = read_eeprom(5);
gara->minutes = read_eeprom(6);
gara->seconds = read_eeprom(7);
gara->vole = read_eeprom_16(8,9);
gara->F_I = read_eeprom(10);
gara->mt = read_eeprom(11);
gara->p_mt90 = read_eeprom_16(12,13);
gara->p_mt70 = read_eeprom_16(14,15);
gara->p_mt50 = fread_eeprom_16(16,17);
gara->p_mt30 = read_eeprom_16(18,19);
gara->p_parz = read_eeprom_16(20,21);
gara->p_tot = read_eeprom_16(22,23);
gara->flag_Rit = read_eeprom(24);
gara->flag_Buz = read_eeprom(25);
where
int8 write_eeprom_16(char msb,char lsb,int16 dato){
int8 reg2,reg1;
int16 reg0;
int8 m_msb,l_lsb;
reg0 = dato & 0xFF00; //msb
reg0 = reg0 >> 8;
m_msb = (int8) reg0;
l_lsb = (int8) dato & 0x00FF;
write_eeprom (msb,m_msb);
write_eeprom (lsb,l_lsb);
int16 read_eeprom_16(char address_h,char address_l){
int8 msb,lsb;
int16 dato,datotot;
msb = read_eeprom(address_h);
lsb = read_eeprom(address_l);
dato = msb;
dato = dato << 8;
dato = dato | lsb;
return dato;
Thanks and excuse me for my English! |
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Fri May 07, 2004 3:04 am |
One quick thing: I strongly recommend you to define these two functions and use them instead:
void my_write_eeprom(byte Adress, byte Value)
write_eeprom(Address,Value);
byte my_read_eeprom(byte Adress)
return read_eeprom(Adress);
Now if you use my_write_eeprom() and my_read_eeprom() your code will be MUCH smaller. |
the_real_maniac Guest
Posted: Sat Jul 16, 2005 1:50 pm |
// ->> ! My english is bad so I hope you understand me. <<- !
I'm have little experience with C , but I almost learnt the basics of C, so here is and my sugestion ;)
Why you don't use bit fields and write the struct at onse ?
example:
struct sometype {
int num;
char ch;
}structname;
and something similar to fread(structname, sizeof(structname), 1, fd);
this reads size_t -> sizeof bytes from fd ... and keep them in structname and you have (default) 8 bits num and 8 bits ch -> 2 bYtes (16bits).
And if you have number like 20 -> 2^2 -> i.e 2 bits and you don't need the whole 8 bits you can use bit fields and in this way to small the used memory at all.
And in main program (program ROM) and when writing the struct in EEPROM.
for example
int num : 2
int char : 7
now you saved almost 1 byte 6+1 = 7 bits of ram just example.
when you read / write to EEPROM this saves time and ram
when you make the main program and write it to program RAM you save space/ memory again.
I hope you understand me , of course is posible i have some misunderstand and the whole my idea is wrong , but "you have to try"
Good luck !
if you have to contact me ;)
the [dot] real [dot] maniac [at] gmail [dot] com |
