SPI Setup for Linear Tech 16 Bit ADC LTC1864
lguancho
PostPosted: Mon May 16, 2005 10:41 pm     Reply with quote
Hi, all. I was experimenting on LTC1864, particularly on how to setup my PIC18F452 (as spi master) to read the 16 bit data. Here are my codes:
#include <18F452.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
#include <input.c>
#include "LTC1864SPI.c"
   int16 dummydata;
   int8 count=1;
   init_ext_adc();
   do
   dummydata= read_ext_adc();
   delay_us(50);
   count++;
   } while (count <=10);
and the driver file
#define ADC_CONV      PIN_D7
#define ADC_DO        PIN_C4   // SDI
#define ADC_DI        PIN_C5   // SDO
#define ADC_CLK       PIN_C3
#bit CKP_BIT=0xFC6.4
#bit CKE_BIT=0xFC7.6
#bit SMP_BIT=0xFC7.7
void init_ext_adc() {
   short int i;
   //output_low(ADC_DI);
   //output_high(ADC_CLK);
   output_low(ADC_CONV);
   i=input(ADC_DO);
   setup_spi(SPI_MASTER|SPI_H_TO_L|SPI_CLK_DIV_16|SPI_SS_DISABLED); //
   CKP_BIT=1;    //SCK IDLE=HIGH
   CKE_BIT=0;
   //SMP_BIT=1;
int16 read_ext_adc(void) {
   BYTE data_hi,data_lo,dummy;
   int16 data;
   output_high(ADC_CONV);
   delay_us(10);
   data_hi=spi_read(0);
   data_lo=spi_read(0);
   dummy=spi_read(0);  // SCK is supplied while Tconv=LOW=> ADC outputs ZEROs
   data=make16(data_hi,data_lo);
   return(data);
My questions:
[1] I tried with the CKP/CKE combination of 1,0 & 1,1. I cannot tell any difference on the SPI Data with respect to SCK clock on my scope. In actual case, what should be the correct setting? LTC1864 Datasheet timing diagram shows that the data changes on falling edges of SCK, so should I use CKP=1, CKE=0?
[2] Any concern about setting of SMP bit in the SSPSTAT register?
Warmest Regards
lguancho
Many thanks
PostPosted: Tue May 17, 2005 3:05 pm     Reply with quote
Look at Figure 1 in the LTC1864 data sheet (page 9) and compare
it to the diagrams of the SPI modes shown in the following link:
http://www.totalphase.com/docs/articles/article03/#modes
The data sheet shows that the idle state of the clock is a high level,
and that it samples the data on the rising edge of clock.
In the link, this is shown as SPI mode 3. The following chart
shows the settings for the CKP and CKE bits for each SPI mode.
SPI mode 0: CKP = 0 and CKE = 1
SPI mode 1: CKP = 0 and CKE = 0
SPI mode 2: CKP = 1 and CKE = 1
SPI mode 3: CKP = 1 and CKE = 0
PostPosted: Tue May 17, 2005 3:54 pm     Reply with quote
As additional info, I always add the following to my code:
// Added SPI Mode defines because CCS and Microchip made a very confusing mess of it.
//     MOTOROLA              MICROCHIP                 CCS
//   SPI Mode 0,0   ==    CKP = 0, CKE = 1   ==   SPI_L_TO_H | SPI_XMIT_L_TO_H
//   SPI Mode 0,1   ==    CKP = 0, CKE = 0   ==   SPI_L_TO_H
//   SPI Mode 1,0   ==    CKP = 1, CKE = 1   ==   SPI_H_TO_L
//   SPI Mode 1,1   ==    CKP = 1, CKE = 0   ==   SPI_H_TO_L | SPI_XMIT_L_TO_H
// Example: setup_spi(SPI_MASTER | SPI_MODE_0_0 | SPI_CLK_DIV_4 );
#define SPI_MODE_0_0  0x4000
#define SPI_MODE_0_1  0x0000
#define SPI_MODE_1_0  0x0010
#define SPI_MODE_1_1  0x4010
lguancho
PostPosted: Tue May 17, 2005 10:30 pm     Reply with quote
Thanks, PCM Programmer and Ckielstra!. I will implement the spi modes as recommended.
About this LTC1864, I find that if I just do two spi-read, the SDATA line will just toogle between HIGH and LOW after the 16 bit data transfer. If I do another spi_read (third ones) while holding the CONV of LTC1864, SDATA line will stay at a nice LOW!!. In fact, this is exactly as per described in the datasheet! Missing this third SPI-READ will cause my code to go astray!
But anyone encounter this kind of issues?
guest
PLease help me on LTC1864 & 16F877A
PostPosted: Thu Jul 14, 2005 5:25 pm     Reply with quote
I modify lguancho's code to use LTC1864 with 16F877a. ADC reading is 0. I have verified the clock (C3), and CONV(D7), but just no signal on DI (C4). Can someone tell me what is wrong?
#include <16f877a.h>
#bit CKP_BIT=0x14.4
#bit CKE_BIT=0x94.6
#bit SMP_BIT=0x94.7
void init_ext_adc();
int16 read_ext_adc(void);
int16 dummydata;
output_high(PIN_C0);
init_ext_adc();
printf("ADC=%lu\r\n", dummydata);
delay_us(50);
CKE_BIT=0;
int16 data;
delay_us(10);
dummy=spi_read(0);
return(data);
