PIC18F4280 - CAN
aaficial
PIC18F4280 - CAN
PostPosted: Tue Jul 12, 2005 1:09 pm     Reply with quote
Hi! I'm using a PIC18F4280. Data is coming in through CANRX. The problem is, the data isn't getting stored in the receive registers in the PIC. I've done tests and changed my code but still no data is being actually stored in the receive registers. What should I do?? Any suggestions anyone?
PostPosted: Tue Jul 12, 2005 1:28 pm     Reply with quote
You mean 18F2480.
According to the data sheet, it's supposed to be backward-compatible
with the 18F458. So, supposedly the CCS driver CAN-18xxx8.C
should work. Have you tried using it with the CCS example file,
EX_CAN.C ?
