What is the difference between the "byte" type of variable and an "int" type of variable?
(I am using an old compiler: 2.686).
Regards
arrow
treitmey
Posted: Wed Jun 29, 2005 10:26 am
In CCS C there is no difference.
All types, except float, by default are unsigned; however, maybe preceded by unsigned or signed.
Thus int defaults to unsigned int which is the same as int8 or a BYTE.
