Jody
Inverted software UART not working why?? with interrupt on B |
Posted: Mon Mar 07, 2011 10:08 am |
I wanted to work with a software UART.. and still have a interrupt.
So mine receive is on pin B0..
And I enabled mine interupt...
The hardware UART doesn't allow me to use the INVERT optie so that's why I use a software UART. Mine hardware is sending a string with at the end 0x0D. (I checked it)
But why o why is this not working???
Regards,
Jody
include the code..... Code: |
#include "C:\MentorProjects\PIC_Code\Test code_USB\main.h"
#include <stdlib.h>
// Includes all USB code and interrupts, as well as the CDC API
#include <usb_cdc.h>
int1 string_ready = FALSE;
unsigned int next_in = 0;
char string[45];
int8 teller = 0;
#int_EXT
void EXT_isr(void)
string[next_in]=getc();
if((string[next_in] == 0x0D) & (next_in > 1)) //Einde string
string_ready = TRUE;
string[next_in+1] = '\0';
next_in=(next_in+1);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
enable_interrupts(INT_EXT);
usb_cdc_init();
usb_init();
for(teller = 0; teller < 45; teller++)
string[teller] = ' ';
next_in = 0;
fprintf(out,"SD2\n");
while(!usb_cdc_connected())
usb_task();
if (usb_enumerated())
if(string_ready == TRUE)
printf(usb_cdc_putc,"code oke");
#include <18F4550.h>
#device adc=8
#FUSES HSPLL //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES DEBUG //Debug mode for use with ICD
#FUSES NOIESO //Internal External Switch Over mode enabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES PLL5 //Divide By 5(20MHz oscillator input)
#FUSES CPUDIV1 //System Clock by 2
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES VREGEN //USB voltage regulator enabled
#FUSES NOICPRT //ICPRT enabled
#use rs232(baud=9600, parity=N,stop=1,xmit=PIN_B1,rcv=PIN_B0,bits=8, invert, stream = out)
//#use rs232(baud=9600,parity=N,stop=1,xmit=PIN_D0,rcv=PIN_D1,bits=8, stream=RFID2)
Posted: Mon Mar 07, 2011 10:52 am |
With invert, the line will be sitting low, and you need to interrupt on the first rising edge. You need to set the interrupt to interrupt on a rising edge, not a falling edge - this should be the default at power on, but safer to set it.....
Also, change the setup_spi line to setup_spi(FALSE);. This is a long running 'mistake' from the wizard, which results in the spi being enabled....
You really _must_ check 'next_in' does not exceed the size of your buffer, or you risk destroying other important data.
Your clock is not 20MHz. You are running the CPU, from the USB PLL. So with CPUDIV1, the CPU is running at 48MHz. Either change the clock setting to the right value, or change the fuse to 'HS', instead of 'HSPLL'.
Jody
Posted: Mon Mar 07, 2011 12:21 pm |
Okee I will check it tomorrow....
As soon as I am in the office..
But THANKS!!! |
Jody
Posted: Tue Mar 08, 2011 4:54 am |
I am doing something wrong.....
I see on the scoop that the RB0 pin is high and going low when there is data comming... But mine incomming data is corrupted....
Is mine baud rate oke??? Or doesn't I use getc()..?? Code: |
#include "C:\MentorProjects\PIC_Code\RFID Test code_USB\main.h"
#include <stdlib.h>
char string[45];
int8 teller = 0;
#int_EXT
void EXT_isr(void)
// string[next_in]=((~getc())+1);
if((string[next_in] == 0x0d) & (next_in > 1)) //Einde string
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_vref(FALSE);
ext_int_edge( H_TO_L ); // Sets up EXT
usb_cdc_init();
usb_init();
next_in = 0;
printf("SD2\r");
usb_task();
printf(usb_cdc_putc,string);
#device adc=8
#FUSES PLL5 //Divide By 4(20MHz oscillator input)
#FUSES CPUDIV2 //System Clock by 2
#use delay(clock=24000000)
//#use rs232(baud=9600, parity=N,stop=1,xmit=PIN_B1,rcv=PIN_B0,bits=8, sample_early, disable_ints, force_sw)
#use rs232(baud=9600, parity=N,stop=1,xmit=PIN_B1,rcv=PIN_B0,bits=8, disable_ints, force_sw, sample_early)
Posted: Tue Mar 08, 2011 5:38 am |
OK. So you have changed to not using 'invert', and using standard TTL serial data.
Your clock rate is wrong again. The CPUDIV2 fuse, from the USB PLL, gives operation at 32MHz.
It is moderately complex, and not helped by CCS's nomenclature.
Divider pattern CCS name division from XTAL division from USB
00 CPUDIV1 1 2
01 CPUDIV2 2 3
10 CPUDIV3 3 4
11 CPUDIV4 4 6
So the CPUDIV2 fuse, gives /2, when running from the crystal (which is why CCS chose the name), but /3, when running off the USB PLL, which is what you have got selected. USB master clock is 96MHz, so your CPU is running at 32MHz, not 24MHz. For 24MHz, you need CPUDIV3.....
In your code that accepts the string, you also need to set 'next_in', back to the start of the buffer, or the second string will start walking over other things in memory....
This may be all that is wrong.
