Code to store tables in code memory
Post new topic   Reply to topic    CCS Forum Index -> Code Library
future
PostPosted: Sat Sep 25, 2004 8:20 pm     Reply with quote
I have this code that works fine with the internal eeprom, but I am limited to 256bytes. Once called it will store the entire struct into eeprom.
I am looking for a way to store this data (a struct) in flash memory.
Thank you.
#int_eeprom
void eeprom_isr(void) {
    /*;  wr - write eeprom complete  ;*/
        if(eecnt<sizeof(cfg)) {
            eeadr=eecnt;
            eedata=*(&cfg+eecnt);
            bit_clear(eecon1,eepgd);  // point to data memory
            bit_set(eecon1,wren);     // enable writes
            eecon2=0x55;              // write 55h
            eecon2=0xAA;              // write AAh
            bit_set(eecon1,wr);       // set wr to begin write
                eecnt++;              // increment index pointer
            } else {
               eecnt=0;
               disable_interrupts(int_eeprom);
pirev
View user's profile Send private message Visit poster's website ICQ Number
PostPosted: Fri Jun 24, 2005 5:48 pm     Reply with quote
// For PIC16F8xx
#bit _C=STATUS.0
#bit GIE=INTCON.7
#bit RD=EECON1.0
#bit WR=EECON1.1
#bit WREN=EECON1.2
#bit EEPGD=EECON1.7
#define _NOP() #asm nop #endasm
void WrPrgMem( int16 dst, int16 data )   {
   // Load destination address
   EEADR = (char)dst;
   EEADRH = 0x1F & ( dst >> 8 );
   // Load data to be programmed
   EEDATA = (char)data;
   EEDATH = data>>8;
   EEPGD = 1;      // Point to program memory location
   WREN = 1;      // Enable write to program memory
   if( GIE )
      _C = 1;
   GIE = 0;      // Disable interrupt
   EECON2 = 0x55; EECON2 = 0xAA;
   WR = 1;         // Start write operation
   _NOP(); _NOP();
   if( _C )
      GIE = 1;   // Enable interrupt
   while( WR );
   WREN = 0;
long RdPrgMem( long src )   {
   EEADR = (char)src;
   EEADRH = 0x1F & ( src >> 8 );
   RD = 1;
   _NOP(); _NOP();
   return (((long)EEDATH)<<8)|EEDATA;
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
