Bad for loop - What happens?
runtimeavl
PostPosted: Wed Jan 25, 2006 2:51 pm     Reply with quote
Hello All,
What happens when I have an integer variable and use it in a for loop that requires a long integer variable?
What would happen to the "t" variable in the code below? it will increment to 255 (since t is declared as integer) and then what? would it be reset to zero, if so, the loop will never exit right?
// Test
int t = 0;
fprintf(PC,"Begin Bad Counter...\r\n");
for (t = 1; t <= 1200; t++) delay_ms(50);
fprintf(PC,"End Bad Counter...\r\n");
Thank you in advance
Peter
coolio
PostPosted: Wed Jan 25, 2006 3:18 pm     Reply with quote
If you increment an unsigned 8-bit value past 255 you will end up at zero. For signed values you will hit -128 once you increment past 127.
SherpaDoug
PostPosted: Thu Jan 26, 2006 8:37 am     Reply with quote
It will loop forever because t <= 1200 will always be true.
