void write_adc_byte(byte data_byte, byte number_of_bits) {
byte i ;
Thanks-
Sophi
Posted: Thu Jun 23, 2005 6:40 pm
It's an alias for "int", which is an 8-bit unsigned integer in CCS.
It's defined in the .H file for your PIC. For example, 16F877.H
contains this line:
#define BYTE int
Look in this folder to find the .H file for your PIC:
c:\Program Files\Picc\Devices
