Problem with function!....HELP ME, please!
micman
PostPosted: Thu Feb 27, 2003 2:08 am     Reply with quote
Hi all,
I have a problem with the funcion,
There are 3 function.
When code compiler, the error is "RECURSION NOT PERMITTED"
WHY?? and as I resolve it!
Thanks all!
the following code:
//------ sf.c --------------
#include "sf.h"
int8 ch,modalita,sec;
const int8 id_mod3 = 0;
const int8 id_mod1 = 2;
const int8 id_mod2 = 4;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
switch (ch)
case (id_mod1):
mod1();
case (id_mod2):
mod2();
case (id_mod3):
mod3();
default:
output_low(PIN_A3);
output_low(PIN_A5);
output_d(0xBF);
output_low(PIN_A4);
void mod1() { //function 1
modalita = read_eeprom(5);
switch (modalita)
case (id_mod1):
sec = read_eeprom(1);
case (id_mod2):
mod2();
case (id_mod3):
mod3();
default:
output_low(PIN_A3);
void mod2() { //function 2
switch (modalita)
case (id_mod1):
mod1();
case (id_mod2):
sec = read_eeprom(2);
case (id_mod3):
mod3();
default:
output_low(PIN_A3);
void mod3() { ////function 3
output_low(PIN_A3);
output_low(PIN_A5);
output_d(0xBF);
output_low(PIN_A4);
// - sf.h -
#include <16F877.h>
#device *=16
#fuses HS,PUT,BROWNOUT,NOWDT
void mod1(void);
void mod2(void);
void mod3(void);
___________________________
Original Post ID: 12160
Robert Holmer
Re: Problem with function!....HELP ME, please!
PostPosted: Thu Feb 27, 2003 3:51 am     Reply with quote
:=Hi all,
:=I have a problem with the funcion,
:=There are 3 function.
:=When code compiler, the error is "RECURSION NOT PERMITTED"
:=WHY?? and as I resolve it!
:=Thanks all!
:=the following code:
Ciao!
Recursion is not allowed with this compiler. MOD1 could call MOD2 and MOD2 could MOD1. Even if it is not going to happen the compiler does not accept it. If one of the calls is removed the compiler will accept the code.
Saluti,
Rob
Original Post ID: 12161
micman
PostPosted: Thu Feb 27, 2003 5:15 am     Reply with quote
Ciao Rob,
Thanks for answer, parli italiano?, I'm Italian
can possible use "goto ....."
example:
mod1(){
label1:
mod2(){
goto label1
Why "goto" only possible within function?
Thanks!
:=:=Hi all,
:=:=I have a problem with the funcion,
:=:=There are 3 function.
:=:=When code compiler, the error is "RECURSION NOT PERMITTED"
:=:=WHY?? and as I resolve it!
:=:=Thanks all!
:=:=the following code:
:=Ciao!
:=Recursion is not allowed with this compiler. MOD1 could call MOD2 and MOD2 could MOD1. Even if it is not going to happen the compiler does not accept it. If one of the calls is removed the compiler will accept the code.
:=Saluti,
:=Rob
Original Post ID: 12164
