Writting to atmel 24c32 eeprom
Enveras
PostPosted: Sat Jun 18, 2005 4:56 pm     Reply with quote
Hallo .
I tried to write to external eeprom atmel 24c32 ,
but no success .
I tried this simple code just for test :
#include <16f84a.h>
#fuses HS,NOWDT
#include <2432.c>
#define I2C_SDA PIN_A0
#define I2C_SCL PIN_A1
main(){
int d;
init_ext_eeprom();
write_ext_eeprom(0x01,0xab);
d = read_ext_eeprom(0x01);
write_eeprom (0, d);
I used 2432.c driver in ccs library.
is there some simple code just to confirm my hardvare connection.
PostPosted: Sat Jun 18, 2005 5:13 pm     Reply with quote
1. The #define statements for the new pin assignments have to go
above the #include statement for the driver. That's the only way
the driver can know about them. Example:
#include <2432.c>
2. You must not let the program fall off the end of main(), or the
PIC will go to sleep. Put a while(1); statement at the end of
your program. Example:
while(1);   // Add this line
3. The normal oscillator fuse setting for a 4 MHz crystal is "XT".
Example:
#fuses XT,NOWDT
