Error in Program Memory 0800h
Nwurma
PostPosted: Tue Jun 14, 2005 2:34 am     Reply with quote
I'm from Switzerland and my English isn't very well, so sorry about that Shocked
I think i have a problem with a function which is too big for the program memory of the 16F877.
When i program the pic using IC-Prog 1.05D, it gives me always a error (when i test the code on the pic) at the program memory address 0800h, this is the first address of the 2nd Page of the program memory.
I've read in the forum that its helpful to use the #SEPARATE command, but for me it doesn't work better with this command..
So,have someone a hint for me?
Greetings
Nwurma
p.s.
maybe the absolute listing is helpful:
CCS PCM C Compiler, Version 3.045, 7671
Filename: C:\C\IPA\IPA.LST
ROM used: 5108 (62%)
Largest free fragment is 2048
RAM used: 78 (45%) at main() level
109 (62%) worst case
Stack: 12 worst case (6 in main + 6 for interrupts)
valemike
PostPosted: Tue Jun 14, 2005 5:42 am     Reply with quote
Did you also add on the top of your .c file:
#device *=16 Question
These 16F devices seem to need the above statement as well as
#separate
my_fxn(void); // function prototype
#separate
my_fxn(void)
// function implementation
nwurma
PostPosted: Tue Jun 14, 2005 7:32 am     Reply with quote
thanks for the fast answer,
but it doesnt help..i have always a bug in the 1stor sometime in the 2nd memory Page (0800h odr 1000h), have you any idea what this could be?
greetings
Re: Error in Programm Memory 0800h
PostPosted: Tue Jun 14, 2005 7:45 am     Reply with quote
Hey wait, i'm looking at the 16F87xA datasheet, and it says that the stack is only 8-deep.
Maybe i'm interpreting it wrong. What problem are you having? Does the program just seem to get 'lost' ?
Nwurma
PostPosted: Tue Jun 14, 2005 8:04 am     Reply with quote
hmmm somewhere i've read that its no problem to need 12 stacks if they are distributed in normal and interrupt stack. Maybe this information was wrong Embarassed
For the 2nd part, not the program get lost, normaly its 1 Byte who is wrong (when i read it out with ic prog) but at times its that after this point ( 0800h or 1000h ) there is also no more text in the Memory Page..
valemike
PostPosted: Tue Jun 14, 2005 8:46 am     Reply with quote
Go grab an 18F442 (or 452 or 4525 or 4520).
Then all you have to worry about now is just your program's functionality. Wink
Also, you should upgrade your compiler version to the most current one, and see what happens.
PostPosted: Tue Jun 14, 2005 9:49 am     Reply with quote
Seperate 'interrupt' stacks exist on some processors, but not on the PIC. Going beyond 8 deep, will stop the program working.
Seperately, your problem sounds like either a faulty chip, or a problem with the programmer. I have seen similar faults with some devices in the past.
PostPosted: Tue Jun 14, 2005 11:42 am     Reply with quote
command, but for me it doesnt work better with this command.
The people that tell you to use #separate are only telling you part of
the story. Normally, the compiler automatically checks the number
of stack levels that it uses, and it takes care so that it doesn't exceed
the permissable number of hardware stack levels available in your PIC.
In the case of the 16F877 there are only 8 stack levels available.
Here is the part they didn't tell you:
If you use #separate, the compiler will not check if the program
uses more than the allowable stack levels. You have to check it
yourself, every time you compile the program. You have to look
at the top of the .LST file and make sure the program only uses a
maximum of 8 levels (for the 16F877). If it uses more than 8 levels,
then you have to modify your program so it doesn't do that.
Look at your .LST file, below. You program uses 12 stack levels, and
that's more than the maximum allowable level of 8. This means your
program will crash at some point. It won't work.
To fix your program, I would get rid of all the #separate statements.
I suspect that you have some very large functions. You may be using
floating point, which uses a lot of ROM. You need to break up your
large functions into several smaller functions. Then the compiler can
more easily place the functions into the 2 KB ROM segments in the
16F877.
nwurma
PostPosted: Tue Jun 21, 2005 1:40 am     Reply with quote
Thank you for the good answers..i've minimized my funktions..some were big ( those for the menu ) and so, know I have 8 stack levels and it works fine on the 16F877, but i've already ordered the 18F452 and for the rest of the project i will work with this microcontroller, although thanks for the good tipps and interesting answers!
Best wishes
nwurma
nwurma
PostPosted: Tue Jun 21, 2005 3:48 am     Reply with quote
ehm a new question..for the pic18f452 i need a new compiler? or is it an entry which i have to do..for changing from the 16f877 to the 18f452?
greetings
