		| Author | Message |
		| tristan
				| Typecast , Rounding issues with printf... |
				|  Posted: Fri Jun 17, 2005 11:48 am |   |
				| I want to be able to adjust a timer value ranging from 0.0 Seconds to 25.5 seconds with a 0-255 byte variable (tim_val) using printf to show the value on the LCD with one decimal point.
 Here is my fprint display line :
 printf(lcd_putc,"\fT%C: \n%S %2.1f Sec",timer_num,LCDMSG[12+language],(float)tim_val/10);      // display Timer adjust screen
 The problem is that this works fine most of the time ...  but:
 0.7 , 0.9 , 1.4 , 1.8 , 1.9 , 2.3 , 2.8 , 3.3 , 3.6 seconds and  so on won't show up...
 I used  %2.2f Sec instead to figure out what was going on, i saw that:
 After 0.60 comes 0.69 ,
 After 0.80 comes 0.89 ,
 After 1.30 comes 1.39  and so on...
 Is there a simple way to fix this and get (0.0 TO 25.5) in 0.1 second increments displaying properly on the LCD?
 Thanks...
		| PCM programmer
				|  Posted: Fri Jun 17, 2005 12:51 pm |   |
				| I made a test program using PCM vs. 3.225 and it works OK. Look at how I do the math in the printf() statement.  I make
 certain that the compiler knows that "10" is a float, by writing
 it as "10.0".    I also make the compiler round off the result
 properly by adding half of your desired precision (on the right
 side of the decimal point) to the result.
  	  | Code: |  	  | #include <16F877.H> #fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
 #use delay(clock = 4000000)
 int8 tim_val;
 for(tim_val = 0; tim_val < 255; tim_val++)
 printf("%u   %2.1f \r",tim_val, (tim_val/10.0) + .05);
 Here is the output:
  	  | Code: |  	  | 0    .0
 1    .1
 2    .2
 3    .3
 4    .4
 5    .5
 6    .6
 7    .7
 8    .8
 9    .9
 10   1.0
 11   1.1
 12   1.2
 13   1.3
 14   1.4
 15   1.5
 16   1.6
 etc.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
