convert float 4bytes => .decimal manually
Christophe
PostPosted: Thu Jun 16, 2005 5:12 am     Reply with quote
a CCS float is: F3F2F1F0 with F0 = LSB and F3 = MSB
How can I convert manually to .decimal?
F0: 128
F1: 111
F2: 175
F3: 175
thanks!
PostPosted: Thu Jun 16, 2005 9:11 am     Reply with quote
Are you asking for a ftoa() routine that runs in CCS ?
or,
Are you asking for a program that runs on a PC, in which you type
in those four numbers and it displays the floating point value ?
Christophe
PostPosted: Fri Jun 17, 2005 1:41 am     Reply with quote
I wanted to calculate on my own, but I found that printf("%f",number);
gives the result.. problem solved!
