Interrupt B0? B1? which interrupt?
jahan
PostPosted: Wed Jun 15, 2005 12:03 pm     Reply with quote
16F877 - PCM 3.223
design has the followings:
push buttons on B0, B1, B2 with pull up resistors.
LEDs on B3, B4, B5.
All LED off at start up.
Can anybody post simple interrupt code to check which switch was pushed (B0,B1,B2) by turning ON one LED (B3, B4, B5 respectively) for 1 second?
jahan
I found isr_rb but it does not check RB0, RB1 or RB2. :(
PostPosted: Wed Jun 15, 2005 1:03 pm     Reply with quote
I found this sample code on CCS web site, but it does not use int_ext.
plus, it can check only on RB4-RB7.
Any suggestion is greatly appriciated.
#int_rb
void rb_isr(void) {
      byte changes;
      changes = last_b ^ port_b;
      last_b = port_b;
      if (bit_test(changes,4 )&& !bit_test(last_b,4)) {
         //b4 went low
      if (bit_test(changes,5)&& !bit_test (last_b,5)) {
         //b5 went low
      delay-ms (100); //debounce
I've been looking for this ... but have not found anything.
PostPosted: Wed Jun 15, 2005 2:20 pm     Reply with quote
jahan, if you found anything , please share it with the rest of forum.
I'll be happy to see it. I'm sure others will too.
-lone-star
jahan
can somebody check this code and bless it.
PostPosted: Wed Jun 15, 2005 3:38 pm     Reply with quote
I've come up with the following code for checking on RB0 or RB1 interrupt and increment a counter for each.
please review and bless (correct) as needed.
your feed back is greatly appreciated.
#include <16F84A.h>
#fuses NOWDT,NOPROTECT
#use delay (clock=4000000)
#use rs232(baud=9600, xmit=PIN_B6, rcv=PIN_B7)
byte FlagB0 = 0;
byte FlagB1 = 0;
char got_interrupt;
char RB0_count, RB1_count;
#bit INTF_BIT0 = 0x0B.0
#bit INTF_BIT1 = 0x0B.1
#int_ext
void int_ext_isr(void) {
   disable_interrupts(INT_EXT);
   got_interrupt = TRUE;
   if (!input(PIN_B0)) {  //B0 = low
      FlagB0 = 1;
      RB0_count++;
   if (!input(PIN_B1)) {  //B1 = low
      FlagB1 = 1;
      RB1_count++;
   clear_interrupt(INT_EXT);
void Handle_Interrupt(void) {
         printf("RB0=%d RB1=%d",RB0_count,RB1_count);
         if (FlagB0 == 1) {
            FlagB0 = 0;    // clear flag
            delay_ms(50);  // debounce
            INTF_BIT0 = 0; // reclear incase during debounce got set again
         if (FlagB1 == 1) {
            FlagB1 = 0;    // clear flag
            INTF_BIT1 = 0;
void main (void) {
   output_float(PIN_B0);
   output_float(PIN_B1);
   port_b_pullups(TRUE);
   delay_us(10);
   RB0_count = 0;
   RB1_count = 1;
   got_interrupt = FALSE;
   ext_int_edge(H_TO_L);
   INTF_BIT0 = 0;
   INTF_BIT1 = 0;
   enable_interrupts(INT_EXT);
   while(true) {
      if (got_interrupt == TRUE) {
         Handle_Interrupt();
PostPosted: Wed Jun 15, 2005 3:46 pm     Reply with quote
There is no interrupt on pin RB1.
From the 16F84A data sheet, in the Special Features of the CPU - Interrupts section:
The PIC16F8X has 4 sources of interrupt:
• External interrupt RB0/INT pin
• TMR0 overflow interrupt
• PORTB change interrupts (pins RB7:RB4)
• Data EEPROM write complete interrupt
jahan
Thank you for your feed back
PostPosted: Wed Jun 15, 2005 4:31 pm     Reply with quote
I could not figure out why I cannot see anything on RB1.
Now I see why!!!
Do you know of any PIC MCU to have more than 1 External INT (similar to RB0 on 16F84A)?
Thankx again.
newguy
PostPosted: Wed Jun 15, 2005 5:45 pm     Reply with quote
The 18F452 has 3 external interrupts: B0, B1, and B2.
Sandgroper
Re: Thank you for your feed back
PostPosted: Wed Jun 15, 2005 6:16 pm     Reply with quote
Now I see why!!!
Thankx again.
You can still use interrupts for multple inputs on the PIUC16F84 but it requires a little more work. The upper four bits on port B support interrupt on change. When the interrupt occurs you read the current port value and compare it to the previous value (similar to jahan's example). The difference is the bit that has changed. However do not do any debouce delays in the interrupt handler. A "cleaner" way of doing the debouce is to start a (debounce) timer in the Interupt on Change (IOC) handler. The timer is reset / restarted whenever an IOC event of interest (ie one of the bits you are interested in) occurs.
Whenever the debouce timer expires you know that it has been "debouce-time" since any of the inputs of interest changes and therefore you have a new "debounce" switch reading available. The timer flag can be polled either in the program body or used to fire a timer interrupt indicating a new value is available.
The disadvantage with this handler is that any read of port b outside the handler will clear the IOC interrupt condition. It also means that if you are using other bits of port B for outputs you cannot use any read-modify-write instructions such as bsf, bcf. This is because the read part of the instruction will clear the IOC flag.
BTW - With the exception of using existing (legacy) development systems, I do not understand why people still use the 16F84 for new projects. It had its day but is now a dinosaur. The 18F family offers significant features, performance and flexibility over the 16F family at a similar price point.
Rgds, Andrew
Christophe
PostPosted: Thu Jun 16, 2005 5:43 am     Reply with quote
just poll your inputs and use a flag...
//*************************** AAN UIT CONTROL ********************************//
         if (!input(AAN_UIT) && !sleep_mode)
            sleep_mode = TRUE;
            printf("%c%S%c",COMMANDO_BYTE, SLEEP_COMMANDO,0);
         if (input(AAN_UIT) && sleep_mode)
            sleep_mode = FALSE;
            printf("%c%S%c",COMMANDO_BYTE, WAKE_COMMANDO,0);
sends command when switch is moved (AAN_UIT)
