QUestion about the calling Tree limit
PostPosted: Wed Jun 15, 2005 12:01 pm     Reply with quote
I check in my function calling tree file, and I see some of the functions have the calling stack up to 7 levels. I remember I read somewhere about the max number of function call level is 8. Is it true? Can anyone help me to elaborate on this topic?
Is case of reaching the max number of calling level, will the CCS compiler will generate an error or warning message or it is the job of the programmer to look into the calling tree file to verify that?
Thank in advance.
B.N
PostPosted: Wed Jun 15, 2005 12:57 pm     Reply with quote
The number of hardware stack levels depends on the processor type you are using, check the datasheet.
Read also the following thread http://www.ccsinfo.com/forum/viewtopic.php?t=23243
PostPosted: Wed Jun 15, 2005 3:56 pm     Reply with quote
Ckielstra,
Thanh you so much for the link and your comments. My pic is 18F8720. The spec. said it has up to 31 software accessable hardware stack.
So far, I have up to 10 levels...I guess I won't have any problem and that why the i don't see any compiler error or warning message regarding to over the calling stack.
CCS PCH C Compiler, Version 3.224, 28569 12-Jun-05 18:19
Filename: C:\Program Files\PICC\projects\Design09\main.LST
ROM used: 23922 bytes (18%)
Largest free fragment is 65536
RAM used: 1817 (47%) at main() level
1873 (49%) worst case
Stack: 10 worst case (7 in main + 3 for interrupts)
B.N
