ADC channel selector for the 16F913
Posted: Wed Jun 15, 2005 9:00 am
I am about to embark on a new project using the 16F913. Before I upgrade my PCM compiler to get the 16F913 capability, can someone please double check for me the ADC channel selector setup.
If I read the data sheet correctly, it looks as if I should be able to set the ADC channels individually using the ANSEL register. This is what i need clarifying - as I only intend to use 3 of the channels for the ADC, the remainder of the port needs to be Digital I/O.
How reliable are the CCS header files for this device as they tend to get them wrong with new chips?
Posted: Wed Jun 15, 2005 9:37 am
These are the constants from 16F913.H for vs. 3.225.
