		| Author | Message |
		| Silver
				| LCD with pic18F452 |
				|  Posted: Mon Jun 13, 2005 2:19 am |   |
				| Thank you for helping me...But I can't still write anything on LCD display. My schematic configuration is:
 4bit data LCD are connected to port D of 18F452 (RD0,RD1,RD2,RD3)
 Enable line on LCD is connected to RA5 of 18F452
 RS and R/W are connected respectively to RD4 and RD5 of 18F452
 How could I modify the source code that you have me linked?
 Thank you again!
		| chingB
				|  Posted: Mon Jun 13, 2005 5:27 am |   |
				| Hi,
 This is what I did for my PIC18F452 with an LCD module connection.
 LCD Pin                       PIC18F452 Pin
 DB4                            RD4
 DB5                            RD5
 DB6                            RD6
 DB7                            RD7
 LCD_EN                      RD0
 RW                             RD2
 RS                              RD1
 My Header File for LCD.H
  	  | Code: |  	  | #ifndef __LCD_H__
 #define __LCD_H__
 // LCD Pin Map Structure
 typedef struct LcdPinMapStruct
 int     unusedA;      // portA is not used
 int     unusedB;      // portB is not used
 int     unusedC;      // portC is not used
 boolean enable;       // PinD0
 boolean rs;           // PinD1
 boolean rw;           // PinD2
 boolean dummy;        // PinD3 is not used
 int     data    :4;   // higher nibble of portD is used for data lines
 } LCD_PIN_MAP_STRUCT;
 // LCD PortA Register Mapping
 #if defined(__PCH__)
 LCD_PIN_MAP_STRUCT LcdPinMapBits;
 #locate LcdPinMapBits = PORTA_BASE
 #else
 #locate LcdPinMapBits = 0x05
 // LCD Tris Structure
 typedef struct LcdTrisMapStruct
 int control    :3;
 int data       :4;  // higher nibble of PortD is used for data lines
 } LCD_TRIS_MAP_STRUCT;
 // LCD TrisA Register Mapping
 LCD_TRIS_MAP_STRUCT LcdTrisMapBits;
 #locate LcdTrisMapBits = TRISA_BASE
 #else
 #locate LcdTrisMapBits = 0x85
 // set Tris on ports for LCD
 #define SET_TRIS_LCD(x)             \
 LcdTrisMapBits.data = (x);  \
 LcdTrisMapBits.control = 0;
 #define LCD_TYPE        (2)     // 0=5x7, 1=5x10, 2=2 lines
 #define LCD_LINE_TWO    (0x40)  // LCD RAM address for the second line
 #define XLAT_OFFSET     (0x80)  // Character Translation Offset
 #define LCD_SIZE        (16)    // Allocated Buffer for LCD Module
 // LCD buffer allocation
 byte LCDbuff[LCD_SIZE];
 // These bytes need to be sent to the LCD to start it up.
 byte const LCD_INIT_STRING[4] = {0x20 | (LCD_TYPE << 2), 0xc, 1, 6};
 // The following are used for setting the I/O port direction register.
 #define LCD_WRITE       0       // For write mode all pins are out
 #define LCD_READ        15      // For read mode data pins are in
 // The following display a string at specified x,y position
 #define LCD_DISPLAY(x,y,string) \
 lcd_gotoxy(x,y);        \
 lcd_putc(string);
 * Function Prototypes                                                         *
 void lcd_init(void);                        // initialize LCD display
 char lcd_getc(byte x, byte y);              // get char from LCD display
 void lcd_putc(char c);                      // put char to LCD display
 void lcd_gotoxy(byte x, byte y);            // set an x,y position
 void lcd_send_byte(byte address, byte n);   // send a byte to LCD display
 void lcd_send_nibble(byte n);               // send a nibble to LCD display
 byte lcd_read_byte(void);                   // read a byte from LCD display
 My Source File for LCD.C
  	  | Code: |  	  | /******************************************************************************
 * Driver for Common LCD Modules                                               *
 * lcd_init()    Must be called before any other function                      *
 * lcd_putc(c)   Will display character (c) on the next position of the LCD    *
 *               The following Parameters:                                     *
 *                   \f  Clear Display                                         *
 *                   \n  Go to start of second line                            *
 *                   \b  Move back one position                                *
 * lcd_gotoxy(x,y)  Set write position on LCD (upper left is 1,1)              *
 * lcd_getc(x,y)    Returns character at position x,y on LCD                   *
 #include "Include\T-Keeper LCD.H"
 * Read a Byte from LCD                                                        *
 byte low, high;
 SET_TRIS_LCD(LCD_READ);     // set data pin to input state (read mode)
 LcdPinMapBits.rw = 1;       // set to rw to high (read mode)
 #asm nop #endasm            // delay for one-clock cycle
 LcdPinMapBits.enable = 1;   // set the enable pin to high
 high = LcdPinMapBits.data;  // get the data from LCD (high nibble)
 LcdPinMapBits.enable = 0;   // set enable pin to low
 LcdPinMapBits.enable = 1;   // set enable pin to high
 low = LcdPinMapBits.data;   // get the data from LCD (low nibble)
 SET_TRIS_LCD(LCD_WRITE);    // set data pin to output state (write mode)
 return ((high << 4) | low); // return result
 * Send Nibble to LCD                                                          *
 LcdPinMapBits.data = n;     // send a nibble to LCD
 delay_us(2);                // delay for 2uSec.
 return;
 * Send Byte to LCD                                                            *
 LcdPinMapBits.rs = 0;       // set rs pin to low
 while (bit_test(lcd_read_byte(),7));
 LcdPinMapBits.rs = address; // provide the address to write
 LcdPinMapBits.rw = 0;       // set rw pin to low (write mode)
 lcd_send_nibble(n >> 4);    // send high nibble to LCD
 lcd_send_nibble(n & 0x0F);  // send low nibble to LCD
 return;
 * Initialize LCD Display                                                      *
 void lcd_init(void)
 byte i;
 SET_TRIS_LCD(LCD_WRITE);    // set all ports to output state (write mode)
 delay_ms(15);               // make a 15mSec. delay
 for(i=1; i<=3; ++i)
 lcd_send_nibble(3);
 delay_ms(5);
 lcd_send_nibble(2);
 for(i=0; i<=3; ++i)
 lcd_send_byte(0,LCD_INIT_STRING[i]);
 for (i=0; i<LCD_SIZE; )
 LCDbuff[i] = 0; i++;
 return;
 * Gotoxy LCD Routine                                                          *
 void lcd_gotoxy(BYTE x, BYTE y)
 byte address;
 if (y != 1)
 address = LCD_LINE_TWO; // if not line1 set address to line2
 address = 0;            // set address to line1
 address += (x - 1);         // increment to next address (line1 or line2)
 lcd_send_byte(0,(0x80 | address));  // send to address to write
 return;
 * LCD Display PutChar Routine                                                 *
 if (c == '\f')      // clear and write to line1
 lcd_send_byte(0,1);
 delay_ms(2);
 return;
 else if (c == '\n') // write to line2
 lcd_gotoxy(1,2);
 return;
 else if (c == '\b') // backspace one position (line1 or line2)
 lcd_send_byte(0,0x10);
 return;
 lcd_send_byte(1,c);
 return;
 * LCD Display GetChar Routine                                                 *
 char value;
 lcd_gotoxy(x,y);         // provide a x,y position
 LcdPinMapBits.rs = 1;    // set rs pin to high
 value = lcd_read_byte(); // get a byte from LCD at x,y position
 return (value);          // return the value
 Hope this would help connect your LCD module to a PIC18F452.
		| chingB
				|  Posted: Mon Jun 13, 2005 5:28 am |   |
				| Hi,
 DB4                            RD4
 DB5                            RD5
 DB6                            RD6
 DB7                            RD7
 LCD_EN                      RD0
 RW                             RD2
 RS                              RD1
 #define __LCD_H__
 #else
 int control    :3;
 #else
 lcd_gotoxy(x,y);        \
 lcd_putc(string);
 byte low, high;
 return;
 return;
 void lcd_init(void)
 byte i;
 for(i=1; i<=3; ++i)
 lcd_send_nibble(3);
 delay_ms(5);
 lcd_send_nibble(2);
 for(i=0; i<=3; ++i)
 return;
 byte address;
 if (y != 1)
 return;
 lcd_send_byte(0,1);
 delay_ms(2);
 return;
 lcd_gotoxy(1,2);
 return;
 return;
 lcd_send_byte(1,c);
 return;
 char value;
		| chingB
				|  Posted: Mon Jun 13, 2005 5:29 am |   |
				| Hi,
 DB4                            RD4
 DB5                            RD5
 DB6                            RD6
 DB7                            RD7
 LCD_EN                      RD0
 RW                             RD2
 RS                              RD1
 #define __LCD_H__
 #else
 int control    :3;
 #else
 lcd_gotoxy(x,y);        \
 lcd_putc(string);
 byte low, high;
 return;
 return;
 void lcd_init(void)
 byte i;
 for(i=1; i<=3; ++i)
 lcd_send_nibble(3);
 delay_ms(5);
 lcd_send_nibble(2);
 for(i=0; i<=3; ++i)
 return;
 byte address;
 if (y != 1)
 return;
 lcd_send_byte(0,1);
 delay_ms(2);
 return;
 lcd_gotoxy(1,2);
 return;
 return;
 lcd_send_byte(1,c);
 return;
 char value;
 | You cannot post new topics in this forum You cannot reply to topics in this forum
