neurus
| Averaging or filtering? |
Posted: Sun Feb 20, 2005 2:08 pm |
hi
In my project I have to make an art integration time. I've an ADC, wich gib me every 0,5 second a value. The integration time goes from 0 to 60 seconds. How can I do to sample the values and calculate the average value of this? It should be as exactly as posible. My ADC is 16 Bits and I'm working with a 18F252 and CCS. Can help me to resolv this problem? has everyone a example to show me how it works?
Thanks and sorry for my english.
Pablo
So works it:
int. time value
0 second every 0,5 second 1 adc value
1 second 2 adc values each 0,5 sec.
10 seconds 20 adc values
etc
I've see a lot of example of filters and averaging routines, but it mus be as exactly as possible.
I forgot something:the process is slowly, the programroutine mus not be to fast but I don't work with float number, if is possible. |
Posted: Mon Feb 21, 2005 6:02 am |
The filters you have seen posted, are almost certainly 'exact'. However there are different kinds of filters for different applications. The best 'compromise', which behaves rather like a leaky integrator, is:
int16 average(int16 adval) {
static int32 avgsum;
int16 result;
avgsum+=adval;
result=avgsum/120;
avgsum-=result;
return(result);
This has the advantage of not needing much storage, giving a nice result, and being relatively quick to calculate. The actual 'damping' level, is set by the divider used, and in terms of fastest speed, and minimum code, using a binary value (2,4, 8 etc.), reduces the time needed for the arithmetic.
The alternative is a simple sum and divide. The downside of this, is that if the result wants to be a 'rolling' value, updated every half second, you need storage for (in your case), 120 int16 values. This is relatively easy on a 18F chip, but may be a problem on the smaller chips. So something like:
static int16 vals[120];
static int8 index;
int16 result;
avgsum+=adval;
avgsum-=vals[index];
vals[index]=adval;
result=avgsum/120;
index=(index+1)%120;
return(result);
This avoids having to add all 120 values each time, by maintaining the sum, and just adding the new value, and subtracting the old.
If you call this with the ADC value, every half second, the returned value, is the sum of the last 120 readings, divided by 120.
guest Guest
| Question for Ttelmah |
Posted: Fri Jun 10, 2005 5:19 pm |
Is there a simple way to throw a flag whenever all 120 values are within +/- 5 of eachother?
Thanks |
