LCD with pic18F452
Silver
LCD with pic18F452
PostPosted: Mon Jun 13, 2005 2:19 am     Reply with quote
Thank you for helping me...But I can't still write anything on LCD display.
My schematic configuration is:
4bit data LCD are connected to port D of 18F452 (RD0,RD1,RD2,RD3)
Enable line on LCD is connected to RA5 of 18F452
RS and R/W are connected respectively to RD4 and RD5 of 18F452
How could I modify the source code that you have me linked?
Thank you again!
chingB
PostPosted: Mon Jun 13, 2005 5:27 am     Reply with quote
This is what I did for my PIC18F452 with an LCD module connection.
LCD Pin PIC18F452 Pin
DB4 RD4
DB5 RD5
DB6 RD6
DB7 RD7
LCD_EN RD0
RW RD2
RS RD1
My Header File for LCD.H
#ifndef __LCD_H__
#define __LCD_H__
// LCD Pin Map Structure
typedef struct LcdPinMapStruct
    int     unusedA;      // portA is not used
    int     unusedB;      // portB is not used
    int     unusedC;      // portC is not used
    boolean enable;       // PinD0
    boolean rs;           // PinD1
    boolean rw;           // PinD2
    boolean dummy;        // PinD3 is not used
    int     data    :4;   // higher nibble of portD is used for data lines
} LCD_PIN_MAP_STRUCT;
// LCD PortA Register Mapping
#if defined(__PCH__)
    LCD_PIN_MAP_STRUCT LcdPinMapBits;
    #locate LcdPinMapBits = PORTA_BASE
#else
    #locate LcdPinMapBits = 0x05
#endif
// LCD Tris Structure
typedef struct LcdTrisMapStruct
    int control    :3;
    int data       :4;  // higher nibble of PortD is used for data lines
} LCD_TRIS_MAP_STRUCT;
// LCD TrisA Register Mapping
    LCD_TRIS_MAP_STRUCT LcdTrisMapBits;
    #locate LcdTrisMapBits = TRISA_BASE
#else
    #locate LcdTrisMapBits = 0x85
#endif
// set Tris on ports for LCD
#define SET_TRIS_LCD(x)             \
        LcdTrisMapBits.data = (x);  \
        LcdTrisMapBits.control = 0;
#define LCD_TYPE        (2)     // 0=5x7, 1=5x10, 2=2 lines
#define LCD_LINE_TWO    (0x40)  // LCD RAM address for the second line
#define XLAT_OFFSET     (0x80)  // Character Translation Offset
#define LCD_SIZE        (16)    // Allocated Buffer for LCD Module
// LCD buffer allocation
byte LCDbuff[LCD_SIZE];
// These bytes need to be sent to the LCD to start it up.
byte const LCD_INIT_STRING[4] = {0x20 | (LCD_TYPE << 2), 0xc, 1, 6};
// The following are used for setting the I/O port direction register.
#define LCD_WRITE       0       // For write mode all pins are out
#define LCD_READ        15      // For read mode data pins are in
// The following display a string at specified x,y position
#define LCD_DISPLAY(x,y,string) \
        lcd_gotoxy(x,y);        \
        lcd_putc(string);
* Function Prototypes                                                         *
void lcd_init(void);                        // initialize LCD display
char lcd_getc(byte x, byte y);              // get char from LCD display
void lcd_putc(char c);                      // put char to LCD display
void lcd_gotoxy(byte x, byte y);            // set an x,y position
void lcd_send_byte(byte address, byte n);   // send a byte to LCD display
void lcd_send_nibble(byte n);               // send a nibble to LCD display
byte lcd_read_byte(void);                   // read a byte from LCD display
#endif
My Source File for LCD.C
* Driver for Common LCD Modules                                               *
* lcd_init()    Must be called before any other function                      *
* lcd_putc(c)   Will display character (c) on the next position of the LCD    *
*               The following Parameters:                                     *
*                   \f  Clear Display                                         *
*                   \n  Go to start of second line                            *
*                   \b  Move back one position                                *
* lcd_gotoxy(x,y)  Set write position on LCD (upper left is 1,1)              *
* lcd_getc(x,y)    Returns character at position x,y on LCD                   *
#include "Include\T-Keeper LCD.H"
* Read a Byte from LCD                                                        *
    byte low, high;
    SET_TRIS_LCD(LCD_READ);     // set data pin to input state (read mode)
    LcdPinMapBits.rw = 1;       // set to rw to high (read mode)
    #asm nop #endasm            // delay for one-clock cycle
    LcdPinMapBits.enable = 1;   // set the enable pin to high
    high = LcdPinMapBits.data;  // get the data from LCD (high nibble)
    LcdPinMapBits.enable = 0;   // set enable pin to low
    LcdPinMapBits.enable = 1;   // set enable pin to high
    low = LcdPinMapBits.data;   // get the data from LCD (low nibble)
    SET_TRIS_LCD(LCD_WRITE);    // set data pin to output state (write mode)
    return ((high << 4) | low); // return result
* Send Nibble to LCD                                                          *
    LcdPinMapBits.data = n;     // send a nibble to LCD
    delay_us(2);                // delay for 2uSec.
    return;
* Send Byte to LCD                                                            *
    LcdPinMapBits.rs = 0;       // set rs pin to low
    while (bit_test(lcd_read_byte(),7));
    LcdPinMapBits.rs = address; // provide the address to write
    LcdPinMapBits.rw = 0;       // set rw pin to low (write mode)
    lcd_send_nibble(n >> 4);    // send high nibble to LCD
    lcd_send_nibble(n & 0x0F);  // send low nibble to LCD
    return;
* Initialize LCD Display                                                      *
void lcd_init(void)
    byte i;
    SET_TRIS_LCD(LCD_WRITE);    // set all ports to output state (write mode)
    delay_ms(15);               // make a 15mSec. delay
    for(i=1; i<=3; ++i)
        lcd_send_nibble(3);
        delay_ms(5);
    lcd_send_nibble(2);
    for(i=0; i<=3; ++i)
        lcd_send_byte(0,LCD_INIT_STRING[i]);
    for (i=0; i<LCD_SIZE; )
        LCDbuff[i] = 0; i++;
    return;
* Gotoxy LCD Routine                                                          *
void lcd_gotoxy(BYTE x, BYTE y)
    byte address;
    if (y != 1)
        address = LCD_LINE_TWO; // if not line1 set address to line2
        address = 0;            // set address to line1
    address += (x - 1);         // increment to next address (line1 or line2)
    lcd_send_byte(0,(0x80 | address));  // send to address to write
    return;
* LCD Display PutChar Routine                                                 *
    if (c == '\f')      // clear and write to line1
        lcd_send_byte(0,1);
        delay_ms(2);
        return;
    else if (c == '\n') // write to line2
        lcd_gotoxy(1,2);
        return;
    else if (c == '\b') // backspace one position (line1 or line2)
        lcd_send_byte(0,0x10);
        return;
        lcd_send_byte(1,c);
        return;
* LCD Display GetChar Routine                                                 *
    char value;
    lcd_gotoxy(x,y);         // provide a x,y position
    LcdPinMapBits.rs = 1;    // set rs pin to high
    value = lcd_read_byte(); // get a byte from LCD at x,y position
    return (value);          // return the value
Hope this would help connect your LCD module to a PIC18F452.
chingB
PostPosted: Mon Jun 13, 2005 5:28 am     Reply with quote
DB4 RD4
DB5 RD5
DB6 RD6
DB7 RD7
LCD_EN RD0
RW RD2
RS RD1
#ifndef __LCD_H__
#define __LCD_H__
#else
#endif
    int control    :3;
#else
#endif
        lcd_gotoxy(x,y);        \
        lcd_putc(string);
#endif
    byte low, high;
    return;
    return;
void lcd_init(void)
    byte i;
    for(i=1; i<=3; ++i)
        lcd_send_nibble(3);
        delay_ms(5);
    lcd_send_nibble(2);
    for(i=0; i<=3; ++i)
    return;
    byte address;
    if (y != 1)
    return;
        lcd_send_byte(0,1);
        delay_ms(2);
        return;
        lcd_gotoxy(1,2);
        return;
        return;
        lcd_send_byte(1,c);
        return;
    char value;
chingB
PostPosted: Mon Jun 13, 2005 5:29 am     Reply with quote
DB4 RD4
DB5 RD5
DB6 RD6
DB7 RD7
LCD_EN RD0
RW RD2
RS RD1
#ifndef __LCD_H__
#define __LCD_H__
#else
#endif
    int control    :3;
#else
#endif
        lcd_gotoxy(x,y);        \
        lcd_putc(string);
#endif
    byte low, high;
    return;
    return;
void lcd_init(void)
    byte i;
    for(i=1; i<=3; ++i)
        lcd_send_nibble(3);
        delay_ms(5);
    lcd_send_nibble(2);
    for(i=0; i<=3; ++i)
    return;
    byte address;
    if (y != 1)
    return;
        lcd_send_byte(0,1);
        delay_ms(2);
        return;
        lcd_gotoxy(1,2);
        return;
        return;
        lcd_send_byte(1,c);
        return;
    char value;
