Pointer and Reference Parameter Inquiry
chingB
PostPosted: Sat Jun 11, 2005 8:48 pm     Reply with quote
According to CCS reference manual...
The compiler has limited support for reference parameters. This increases the readability of code and the efficiency of some inline procedures. The following two procedures are the same. The one with reference parameters will be implemented with greater efficiency when it is inline.
funct_a(int*x,int*y){
   /*Traditional*/
   if(*x!=5)
   *y=*x+3;
funct_a(&a,&b);
funct_b(int&x,int&y){
   /*Reference params*/
   if(x!=5)
   y=x+3;
funct_b(a,b);
In relation with this, the driver for DS1302 uses the reference parameter and it confuse me coz I usually use the * ptr symbol for passing data to a varaible.
Can anybody explain this such that I can be enlighten?
BTW, is this reference parameter method is an ANSI-C standard?
Would it be possible to change the function declaration:
From
void rtc_get_date(BYTE &day, BYTE &mth, BYTE &year, BYTE &dow);
void rtc_get_time(BYTE &hr, BYTE &min, BYTE *sec);
To
void rtc_get_date(BYTE *day, BYTE *mth, BYTE *year, BYTE *dow);
void rtc_get_time(BYTE *hr, BYTE *min, BYTE *sec);
then, I am going use the function such as:
   byte day,mth,year,dow,hour,min,sec;
   rtc_init();
   while (TRUE) {
      rtc_get_date( &day, &mth, &year, &dow);
      rtc_get_time( &hour, &min, &sec );
            printf(lcd_putc,"%2X/%2X/%2X\n%2X:%2X:%2X",day,mth,year,hour,min,sec);
      delay_ms(250);
I also simulate this code to Visual C++ and it says a syntax error!!! code listed below.
void ds1302_get_date(char &Day, char &Month, char &Year, char &DayOfWeek)
    Day = 0x05;      // get day
    Month = 0x10;    // get month
    Year = 0x05;     // get year
    DayOfWeek = 0x03; // get days of the week
    return;
   char Day;
   char Month;
   char Year;
   char DayOfWeek;
   ds1302_get_date(Day, Month, Year, DayOfWeek);
   getchar();
   return;
I guess VC++ does not support reference parameter? Am I right?
I need your insights on this matter.
Thank u.
PostPosted: Sat Jun 11, 2005 11:38 pm     Reply with quote
It does compile under MSVC++, but you have to give your file
an extension of .cpp, instead of .c
Here is a brief description of it on a C++ webpage:
http://www.cs.wisc.edu/~hasti/cs368/CppTutorial/NOTES/PARAMS.html#ref
Mark
PostPosted: Sun Jun 12, 2005 8:37 am     Reply with quote
If the function is implemented inline and you used reference parms then I suspect the compiler wouldn't need to load temp variables for the parms. This also makes the function a little easier to read since some people have trouble with pointer notation.
