please check this small code!
John Mayer
PostPosted: Fri Jun 03, 2005 12:22 pm     Reply with quote
I want to check the state of time. If timer reaches 1 hour triggerMe shoud be activated. Timer is counting correctly and all is working but i can't activate the triggerMe part... Chip is 16f877 on 4 mHZ.
Part of the code:
int triggerMe=0;
#INT_TIMER1
void clock_isr()
      if(--int_count==0)
         ++sec;
         int_count = INTS_PER_SECOND;
   if(sec==60)
      sec=0;
      min++;
         if(min==60)
                triggerMe=1;
if (triggerMe==1)
   min=0;
   printf(lcd_putc,"f You reach one hour");
void main ()
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
DragonPIC
PostPosted: Fri Jun 03, 2005 1:25 pm     Reply with quote
your missing a closing brace '}' after your first if statement in the ISR. Also, make sure
if (triggerMe==1)
   min=0;
is within the braces of the ISR funtion.
-Matt
treitmey
PostPosted: Fri Jun 03, 2005 2:36 pm     Reply with quote
I changed your clock to match my 16MhZ and changed 2sec/min and 2min/hr
but this now works
#include <16F877.h>
#device *=16
#use delay(clock=16000000)
#fuses HS,NOWDT,NOLVP,PROTECT,PUT,BROWNOUT
#use rs232(baud=19200,xmit=PIN_A3,INVERT,stream=DEBUG) // STDERR(same as DEBUG)
#case
#zero_ram
#define VER_MAJOR 1
#define VER_MINOR 02
#define INTS_PER_SECOND 200
int8 int_count;
int8 sec,min;
int1 triggerMe=FALSE;
void main ()
  int_count=INTS_PER_SECOND;
  fprintf(DEBUG,"Starting\n\r");
  while (TRUE){
    if (triggerMe)
      triggerMe=FALSE;
      fprintf(DEBUG,"You reach one hour\n\r");
#INT_TIMER1
void clock_isr()
  //fprintf(DEBUG,"-");
  if(--int_count==0)
    sec++;
    fprintf(DEBUG,".");
    if(sec==2)
      sec=0;
      min++;
    if(min==2)
      triggerMe=TRUE;
      min=0;
notice.
1-enable interupts (gloabal)
2-a while(true) loop so your code doesn't drop out to 'no-mans-land' and restart
3-take out the printf in the ISR, it is just for debugging
John Mayer
PostPosted: Sat Jun 04, 2005 7:22 am     Reply with quote
Nice solution but there is small problemm in my case. Im triggering this action (*You have reached 1 our or more*) only then when user clicks some button ( status check ), so i can not wait in while till the time is out.
If i take while out then nothing happens.
Do you have some solution for that?
John
libor
PostPosted: Sat Jun 04, 2005 8:23 am     Reply with quote
You then put the 'if (triggerMe)...' to the code block executed when the user clicks those buttons.
John Mayer
PostPosted: Sat Jun 04, 2005 9:37 am     Reply with quote
Yes i did that but then time is counting like there is no block.
Example: If i start counting at 0 and wenn i reach 5 minutes i press status button, but there is no message. Time is counting further like nothing happens..
