PIC16c765 input() problem :(
tramper2
PostPosted: Thu Jun 02, 2005 5:31 am     Reply with quote
hi there~
i'm not a good at english please understand.
my board has 6 switch and its connected with RA0~RA5 of pic16c765.
but it's not working except RA4.
my code like bellows
if(input(PIN_A0)) ~~
so i had changed switch to RB0~RB5 and its worked well
if(input(PIN_B0)) ~~
what is different RA with RB port??
my compiler is ccsc 3.203
thanks
PostPosted: Thu Jun 02, 2005 10:38 am     Reply with quote
Have you actually set portA, to be used for digital I/O?. By default chips with ADC units, wake up with the analog bits on port A, set to work as analog I/O, usually with the exception of A4.
You need to add:
setup_adc(NO_ANALOGS );
to switch these pins to digital operation.
tramper2
thanks Ttelmah
PostPosted: Thu Jun 02, 2005 6:25 pm     Reply with quote
i'll try it ~~
thanks you very much
