rs232 change baud within program.
sadlpx
PostPosted: Wed Jun 01, 2005 11:31 am     Reply with quote
I'm trying to build a simple RS232 comm checker to read messages sent in both directions. When i hard code one baud rate (set at compile) it work fine. next step is the change the baud rate or invert poliarity with a switch dinamically within the program once it is running. any suggestions.
valemike
PostPosted: Wed Jun 01, 2005 11:45 am     Reply with quote
You can do another #use_rs232 statement anywhere else in your program. From that point on in your program, it will use those settings.
PostPosted: Wed Jun 01, 2005 12:07 pm     Reply with quote
Use the board's search engine to search for set_uart_speed
and also autobaud. There are lots of threads on these topics.
