int_rda
RodeKlu
int_rda
PostPosted: Tue May 31, 2005 11:31 am     Reply with quote
Hi All,
I'm having trouble with the rda interrupt. I checked the communication with this program:
// type of pic
#include <16F628.h>
// osc., no watchdog, power up timer,no protect
#fuses XT,NOWDT,PUT,NOPROTECT
// progr id V 100
#id 0x0100
// 4 MHz clock
#use delay (clock=4000000)
#use rs232 (baud=9600, parity=N, bits=8, rcv=PIN_B1)
#define LED PIN_B7
short select=FALSE;
void main(void){
   while(TRUE){
      if (kbhit()){
         getc();
         if(select){
            select = FALSE;
            output_low(LED);
         }else{
            select = TRUE;
            output_high(LED);
It worked so I changed it to:
// type of pic
#include <16F628.h>
// progr id V 101
#id 0x0101
// 4 MHz clock
#define LED PIN_B7
short select=FALSE;
#int_rda
void rda_isr(void){
   int receive;
   receive=getc();
   if(select){
      select = FALSE;
      output_low(LED);
   }else{
      select = TRUE;
      output_high(LED);
   return;
void main(void){
   enable_interrupts(global);
   enable_interrupts(int_rda);
   while(TRUE){
And that code did not do what I expected.
Does anybody know what I'm doing wrong?
Thanks,
Rob.
rwyoung
PostPosted: Tue May 31, 2005 1:44 pm     Reply with quote
Confirm that the compiler is using the hardware UART. Since you didn't specify the transmit pin in your #use rs232 statement I'm not sure what the compiler will generate. Specify the appropriate pin for transmit, PIN_B2 I believe.
Then check your LST file to see if the code generated for your getc and kbhit is using the UART registers or if it is calling bit-banging code.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
PostPosted: Tue May 31, 2005 2:05 pm     Reply with quote
Yes, perhaps you are defaulting to a software interrupt. Try to ensure the hardware USART is used by explicityly giving proper Rx and Tx pins. Try this
#USE RS232(BAUD=9600, XMIT=PIN_B2, RCV=PIN_B1, ERRORS)
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Tue May 31, 2005 11:17 pm     Reply with quote
You might be missing characters when you are in the delay_ms(1000).
What kind of missbehavior are you getting?
PostPosted: Tue May 31, 2005 11:41 pm     Reply with quote
No, it's because of what the others suggested -- If you only define
one hardware pin in the #use rs232() statement, the compiler inserts
a soft UART and there is no rda interrupt. See these posts:
http://www.ccsinfo.com/forum/viewtopic.php?t=17803
http://www.ccsinfo.com/forum/viewtopic.php?t=22028
RodeKlu
PostPosted: Wed Jun 01, 2005 5:54 am     Reply with quote
I added the transmit line and it worked fine. The other posts answer my question if I could still use the transmit line in another way. I can.
Thanks for the help,
Rob.
