printf or sprintf and puts
pfournier
PostPosted: Tue May 24, 2005 8:15 am     Reply with quote
Does anyone know right off the bat, which would consume the least amount of code space, a printf or a sprintf followed by a puts?
-Pete
-Pete
PostPosted: Tue May 24, 2005 1:28 pm     Reply with quote
Compile some test files and look at the ROM usage that's given at the top
of the .LST file. You'll see something like this:
ROM used: 22 words (0%)
Largest free fragment is 2048
RAM used: 6 (3%) at main() level
6 (3%) worst case
Stack: 0 locations
This tells you that this test program used 22 ROM locations.
pfournier
PostPosted: Wed May 25, 2005 5:40 am     Reply with quote
I'll let you know what I find
-Pete
pfournier
PostPosted: Thu May 26, 2005 10:11 am     Reply with quote
Here is what I ran.
Here are the code sizes.
With the simple printf it was 98, sprintf was 180
With the printf with a variable it was 344, sprintf was 426
I guess printf wins.
-Pete
char buffer[20];
char count=1;
//printf("test\n\r");
//sprintf(buffer, "test\n\r");
//puts(buffer);
//printf("Count %04d\n", Count);
sprintf(buffer, "Count %04d\n", Count);
puts(buffer);
-Pete
PostPosted: Thu May 26, 2005 10:25 am     Reply with quote
It is what I'd 'expect, since with the sprintf, you are adding two sets of character array accesses, but it is nice to have it confirmed.
pfournier
PostPosted: Thu May 26, 2005 10:49 am     Reply with quote
This was interesting because I am told that with the Dynamic C compiler on the Rabbit processor the reverse is true. I gotta try that out when I get time.
-Pete
PostPosted: Thu May 26, 2005 1:18 pm     Reply with quote
That might make sense, if the compiler uses a form of buffered I/O, and 'knows' to do a single memory copy from the string to the buffer. Or if the individual 'putc' commands used inside the printf, are 'inline', and appear in a lot of places. With a normal I/O structure it does not make sense.
DragonPIC
PostPosted: Fri May 27, 2005 1:05 pm     Reply with quote
Does the CCS compiler optimize when printf is used more often in the same program? Is there anything else that could cause printf to compile differently? You might have to do another test to confirm total use.
-Matt
