Error 91
cogen
Error 91
PostPosted: Sat Jun 30, 2007 1:43 pm     Reply with quote
Hello all
Pic 12f675
CCS Vers 4.019
When I compile delay_ms(96), I get:
Error 91 "D:\CTI\alteronics\osc\Controller Code\oscillator.c" Line 57(10,12): Expression must be a constant or simple variable ::
If I compile above with delay_ms(95) or delay_ms(97) it compiles fine, any suggestions?
PostPosted: Sat Jun 30, 2007 3:17 pm     Reply with quote
Post a compilable test program that shows the problem. Make it
complete, but as short as possible. Here's an example of a test program:
http://www.ccsinfo.com/forum/viewtopic.php?t=27950&start=8
Just as that program shows, post all #include, #fuses, and #use
statements. Make the main body of the program be very short.
cogen
PostPosted: Sat Jun 30, 2007 8:16 pm     Reply with quote
#include "D:\CTI\alteronics\osc\Controller Code\PWM_osc\temp.h"
   setup_adc(ADC_OFF);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_32);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   // TODO: USER CODE!!
delay_ms(96);
Error message:
*** Error 91 "D:\CTI\alteronics\osc\Controller Code\oscillator.c" Line 57(10,12): Expression must be a constant or simple variable ::
   setup_adc(ADC_OFF);
   setup_vref(FALSE);
delay_ms(95);
Compiles fine....
cogen
temp.h
PostPosted: Sat Jun 30, 2007 8:20 pm     Reply with quote
#include <12F675.h>
#device adc=8
#FUSES XT                       //Crystal osc <= 4mhz
#FUSES MCLR                     //Master Clear pin enabled
#FUSES PUT                      //Power Up Timer
#use delay(clock=32768)
cogen
error message
PostPosted: Sat Jun 30, 2007 8:24 pm     Reply with quote
The error message i posted was pasted from the original program. If you need the error message from the test program I will retype, although the only difference is the line and column numbers: Line 17(10,12) rather than Line 57(10,12)
thanks in advance.
mike
PostPosted: Sat Jun 30, 2007 11:27 pm     Reply with quote
It's a bug in the compiler. It's not just your version. I found the
same bug with vs. 3.249 and 4.042. It's also there with the 16F877.
I think it's a problem that's only seen with a very low frequency clock
such as the 32.768 KHz watch crystal.
To study the problem, I modified your program into the test program
shown below.
#include <12F675.h>
#device adc=8
#FUSES NOWDT        // No Watch Dog Timer
#FUSES LP           // Watch Crystal osc
#FUSES NOCPD        // No EE protection
#FUSES NOPROTECT    // Code not protected from reading
#FUSES MCLR         // Master Clear pin enabled
#FUSES PUT          // Power Up Timer
#FUSES NOBROWNOUT   // No brownout reset
   delay_ms(93);
   delay_ms(94);
   delay_ms(95);
   delay_ms(97);
This produces the loop code shown below. You can see that they use
inline loops to do the delay up to 95 ms. At 97 ms, they call a library
routine (not shown) which does an 1 ms delay. You can see that they
pass it the parameter of 0x61, which is 97 decimal.
It looks to me like they have a problem with their code generator, in the
part that checks when to start using the 1 ms delay routine in the library
code. Somehow, they let the value of 96 fall through, and it's not
considered valid for either the loop or the library delay code. Therefore
it generates an error message. They may be using a "less than" test,
and they need to use a "less than or equal to" test.
You can report this bug and if your maintenance has run out, I think
they'll probably upgrade you to the new working version.
.................... while(1)
....................    delay_ms(93);
0022:  MOVLW  F7
0023:  MOVWF  20
0024:  DECFSZ 20,F
0025:  GOTO   024
0026:  NOP
0027:  NOP
....................    delay_ms(94);
0028:  MOVLW  FA
0029:  MOVWF  20
002A:  DECFSZ 20,F
002B:  GOTO   02A
002C:  NOP
....................    delay_ms(95);
002D:  MOVLW  FD
002E:  MOVWF  20
002F:  DECFSZ 20,F
0030:  GOTO   02F
....................    delay_ms(97);
0031:  MOVLW  61
0032:  MOVWF  23
0033:  GOTO   004
0034:  GOTO   022
As a work-around, you could do this to get a 96 ms delay:
delay_ms(95);
delay_ms(1);
One more thing -- you had the 'XT' fuse in your posted code. The data
sheet recommends using the 'LP' fuse with a 32.768 KHz watch crystal,
so I changed it to that.
cogen
Error 91
PostPosted: Sun Jul 01, 2007 8:30 am     Reply with quote
Thank you for your response. I will follow up with tech support. I also agree about the low power setting for the watch crystal. I have a fairly long startup using LP and have found that the XT setting starts quickly and works better for development efforts, (a nuance, I know). Again, thank you.
Mike
