Charles Linquist
| interrupt issue |
Posted: Mon May 23, 2005 9:23 pm |
I'm using several interrupts (TMR0, AD, RDA).
Whenever I execute the line:
disable_interrupts(int_RDA);
It seems to disable ALL the interrupts. When I execute the line:
enable_interrupts(int_RDA);
The interrupts start working again.
Why would disabling one interrupt affect all interrupts? |
Mark
Posted: Mon May 23, 2005 9:49 pm |
| It shouldn't |
Charles Linquist
Posted: Mon May 23, 2005 9:56 pm |
I'm thinking that the issue could be because I'm disabling the interrupt INSIDE the ISR. I'm enabling it again before the routine exits.
Is that allowed? |
Posted: Mon May 23, 2005 10:19 pm |
I noticed in another post that you're doing this:
| Quote: | | #use rs232(BAUD=9600,XMIT=PIN_C6,RCV=PIN_C7) |
If you do this and you're shutting off interrupts at various times,
I think it's likely that you're getting a locked-up UART receiver.
You should be doing this:
| Quote: | | #use rs232(BAUD=9600,XMIT=PIN_C6,RCV=PIN_C7,ERRORS) |
You should always do it that way. |
Charles Linquist
Posted: Mon May 23, 2005 11:17 pm |
Thanks, I had already added that statement.
I found my problem.... I had a "leak" in one of my routines that shut off and re-enabled global ints by mistake.
Right now, I think I should stop trying to add functionality, and focus on style, readability and accuracy. |
