what happens with this pin?
Christophe
PostPosted: Tue May 24, 2005 4:00 am     Reply with quote
review this piece of code:
#define BR_STROBE PIN_C4
main()
output_low(BR_SLEEP);
setup_spi (SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H|SPI_CLK_DIV_4);
What has happened with pin C4 ( = SDI of the SPI peripheral). I want to use it as an spi-independant I/O. -or I only want to use the master interface of the SPI.
edit:
How can you disable the SPI in CCS-C ?
valemike
PostPosted: Tue May 24, 2005 5:22 am     Reply with quote
Assuming RC4 is part of the SPI MSSP module, then your setup_spi module will override any tris settings you have for the tris bits.
You'll have to choose another pin for io.
Christophe
PostPosted: Tue May 24, 2005 6:11 am     Reply with quote
what if I switch those statements?
Mark
PostPosted: Tue May 24, 2005 6:20 am     Reply with quote
What if you read the datasheet for the PIC?
Christophe
PostPosted: Tue May 24, 2005 8:04 am     Reply with quote
Any serial port function that is not desired may be
overridden by programming the corresponding data
direction (TRIS) register to the opposite value.
I'm sorry that I was for any inconvenience for you, Mark
Mark
PostPosted: Tue May 24, 2005 11:09 am     Reply with quote
Didn't inconvenience me Smile I was just helping you to help yourself.
