ADC_18F458 Guest
Problem with adc in 18F458 |
Posted: Mon May 23, 2005 9:15 pm |
I am using five adc channels in a pic18F458 and I use for testing ANO and the others connected to ground (AN1, AN2, AN3, AN4) and I get a lot of garbage in Hyperterminal:
0, 0, 0, 64, 0
0, 0, 0, 0, 64
0, 0, 64, 0, 0
0, 0, 0, 0, 0
0, 0, 0, 0, 64
0, 0, 64, 0, 0
64, 0, 64, 0, 0
0, 0, 64, 0, 0
0, 0, 0, 0, 0
64, 0, 64, 0, 0
0, 0, 0, 0, 0
64, 0, 0, 0, 0
0, 0, 0, 0, 0
64, 0, 64, 0, 0
64, 0, 0, 0, 64
64, 0, 64, 64, 0
64, 0, 64, 64, 0
128, 0, 0, 0, 0
64, 0, 64, 64, 0
0, 64, 64, 64, 0
64, 0, 64, 64, 0
128, 64, 0, 0, 64
0, 0, 0, 0, 0
0, 0, 0, 64, 0
64, 0, 0, 0, 0
Here is only working AN0, and the others are connected to ground
#if defined(__PCH__)
#include <18F458.h>
#device ADC=16
#use delay(clock=10000000)
int ch0,ch1,ch2,ch3,ch4;
char coma;
setup_port_a( ALL_ANALOG );
setup_adc( ADC_CLOCK_INTERNAL );
coma = ',';
while (TRUE)
set_adc_channel(0);
delay_us(10);
ch0 = Read_ADC();
printf("%3U%C",ch0,coma);
delay_ms(10);
set_adc_channel(1);
delay_us(10);
ch1 = Read_ADC();
printf("%3U%C",ch1,coma);
delay_ms(10);
set_adc_channel(2);
delay_us(10);
ch2 = Read_ADC();
printf("%3U%C",ch2,coma);
delay_ms(10);
set_adc_channel(3);
delay_us(10);
ch3 = Read_ADC();
printf("%3U%C",ch3,coma);
delay_ms(10);
set_adc_channel(4);
delay_us(10);
ch4 = Read_ADC();
printf("%3U\r\n",ch4);
delay_ms(10);
Thanks for your help!!! |
Posted: Mon May 23, 2005 10:01 pm |
Make the changes shown in bold below:
Quote: | #include <18F458.h>
#device ADC=10
int16 ch0,ch1,ch2,ch3,ch4;
char coma;
setup_adc(ADC_CLOCK_DIV_16);
coma = ',';
while (TRUE)
set_adc_channel(0);
delay_us(10);
ch0 = Read_ADC();
printf("%LU%C",ch0,coma);
delay_ms(10);
set_adc_channel(1);
delay_us(10);
ch1 = Read_ADC();
printf("%LU%C",ch1,coma);
delay_ms(10);
set_adc_channel(2);
delay_us(10);
ch2 = Read_ADC();
printf("%LU%C",ch2,coma);
delay_ms(10);
set_adc_channel(3);
delay_us(10);
ch3 = Read_ADC();
printf("%LU%C",ch3,coma);
delay_ms(10);
set_adc_channel(4);
delay_us(10);
ch4 = Read_ADC();
printf("%LU\r\n",ch4);
delay_ms(10);
