24LC512 Microchip EEPROM
guest
PostPosted: Sun May 22, 2005 10:31 pm     Reply with quote
I need to do a data logger using a 24LC512 Microchip EEPROM, the driver that CCS has it is for 24LC256, how can I do for use a 24LC512.
I need to record 5 adc signals, and then send it via rs232 to a pc.
Thanks,
Fernando
PostPosted: Mon May 23, 2005 12:56 am     Reply with quote
See the Data Logger project on this page:
http://www.vermontficks.org/pic.htm
There is a 24LC512 eeprom driver in the Code Library:
http://www.ccsinfo.com/forum/viewtopic.php?t=22587
Mark
PostPosted: Mon May 23, 2005 6:06 am     Reply with quote
Had there not been a driver in the library, you would look at the datasheets for both devices. Find out what is different between the two and then modify the existing driver.
Fernando
PostPosted: Mon May 23, 2005 4:05 pm     Reply with quote
Thanks for you information, i am going to try to do my pic program using it. First, I'm going to record one adc channel, record data on memory and then recovery using RS232.
PostPosted: Mon May 23, 2005 4:14 pm     Reply with quote
I used one of these a while back - as I recall, I just took the 24256 driver as supplied and modified the EEPROM_SIZE definition. Worked fine for me.
