Charles Linquist
Functions, Math |
Posted: Sun May 22, 2005 12:56 pm |
I have taught myself enough to get some things working, but now I need functions. I'm trying to clear a keyboard buffer, and I have the following lines in my program
Clear_Keyboard_Buffer()
for (i=0;i<11;i++)
{Keyin_buffer[i] = 0;}
return;
I want to be able to issue the command "Clear_Keyboard_Buffer" and
have the program run off and do that.
Unfortunately, when I compile, I get the message "Undefined Identifier - Clear_Keyboard_Buffer".
What do I need to change in order to get this to do what I want?
Next question: I am accepting characters from the keyboard in an array, and I need to filter out certain characters, such as <CR> and <ESC>. In another (un-named) language, I would define my input as INT and would look for 0x0D, etc. When I wanted to display the characters, I would add 0x30 and display them. In C, is there a way to trap control characters such as <ENTER> and <ESC> using type 'char'? If not and I have to store the input as 'int', then how do I convert the type to 'char" in order to display what was typed? |
Posted: Sun May 22, 2005 2:32 pm |
int i;
for (i=0;i<11;i++)
You do not need the brackets round the 'keyin_buffer[i]=0' statement, but you do need them round the body of code. Also any variabels used locally (I am assuming that 'keyin_buffer' is declared globally), ust be declared inside the function.
This declaration should either appear before you want to use the function, or you need a 'prototype' declaration before you use the function - just:
Clear_Keyboard_Buffer();
In the body of the code, outside any functions, before you want to use the command.
If 'i' is also global, then you could just use a macro definition instead, with:
#define Clear_Keyboard_Buffer() for (i=0;i<11;i++) \
Keyin_buffer[i] = 0
Here this 'block' of code will be subsituted into the compiled result. Note the '\' which stops the line feed from ending the statement, and the lack of a trailing ';', since the one typed after the command will still be here.
Again the definition must be before the operation is used.
