16F88 Comparator Problem
PostPosted: Wed May 18, 2005 8:31 pm     Reply with quote
Has anyone experienced a problem reading C1OUT from CMCON on a 16F88? I can see C1OUT on RA3 but I cannot read it in code.
#include <16F88.h>
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOMCLR
#Use FAST_IO(A)
#Use FAST_IO(B)
#BYTE VRCONREG = 0x9D
#BYTE CMCON = 0x9C
main() {
int8 Comp;
SET_TRIS_A(0x03);
SET_TRIS_B(0x04);
OUTPUT_HIGH(PIN_B1);
DELAY_MS(1000);
OUTPUT_LOW(PIN_B1);
VRCONREG=0xE2;
CMCON = 6;
{ Comp=CMCON;
if(BIT_TEST(Comp,6)){
Delay_us(100);
OUTPUT_HIGH(PIN_B3);}
if(!BIT_TEST(Comp,6)){
Delay_us(100);
OUTPUT_LOW(PIN_B3);}
PostPosted: Thu May 19, 2005 12:10 am     Reply with quote
It looks like you're trying to use the internal Vref with the comparators
in mode 6. However, according to the data sheet, the internal Vref is
only used in mode 2. I can confirm this. I ran the following test
program and it only worked in mode 2.
I used a 16F88 on a PicDem2-Plus board, and I set the trimpot for
an output voltage of 2.5v. When I ran the program below, and
moved the trimpot wheel back and forth very slightly, I got this output:
00
00
00
01
01
01
00
00
00
01
01
01
etc.
#include <16F88.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock=8000000)
#use RS232(baud=9600, xmit=PIN_B5, rcv=PIN_B2, ERRORS)
setup_oscillator(OSC_8MHZ);
setup_comparator(A0_VR_A1_VR);  // Comparator mode 2
setup_vref(VREF_LOW | 12);    // Set internal Vref = Vdd/2
   printf("%x\n\r", C1OUT);  // Display C1 output every 1/2 second
