Compiler Error
neurus
Compiler Error
PostPosted: Wed May 18, 2005 12:20 am     Reply with quote
hi
I've the following code
void listo_enviar(void)
   do
           putc(modbus.txData[Buffindex]);//line 53
           ++Buffindex;//line 54
    while(Buffindex<FrametoSend);
and when I try to compile it, I get the following compiler error:
" *** Error 66 "U:\Temp\Soft_Andres\Projecto\inter_control.c" Line 53(25,34): Previous identifier must be a pointer"
Has everybody any idea?
Pablo
PostPosted: Wed May 18, 2005 12:58 am     Reply with quote
You didn't provide a test program, and it's hard to test the code
without one, so I made one and it compiles without any errors.
I tested it with PCM vs. 3.224. See below:
#include <16F877.H>
#use delay(clock = 4000000)
struct
char c;
char txData[10];
}modbus;
char Buffindex;
char FrametoSend;
do{
   ++Buffindex;
  }while(Buffindex<FrametoSend);
Buffindex = 0;
listo_enviar();
