driving of module
Christophe
driving of module
PostPosted: Tue May 17, 2005 3:24 am     Reply with quote
http://expand.xs4all.nl/uploadarchief/download.do?file=CELL_V6_15.pdf
This is the datasheet of the module I need to drive (it is a braille-cell - makes blind people able to read).
I wanted to know if I can use the SPI module for driving this? And if yes, what is the configuration of it?
PostPosted: Tue May 17, 2005 5:40 am     Reply with quote
Your circuit uses 10 data bits while SPI uses 8 data bits, this makes it impossible to use SPI.
Writing your own function to output this data is very easy:
#define CLOCK_PIN   PIN_B1
#define DATA_PIN    PIN_B2
#define STROBE_PIN  PIN_B3
write_braille(int16 Data)
  int8 i;
  for (i=0; i<10; i++)
    // Output data bit
    if ( bit_test(Data, i) )
      output_high(DATA_PIN);
      output_low(DATA_PIN);
    delay_us(1);
    // Clock pulse
    output_high(CLOCK_PIN);
    delay_us(1);
    output_low(CLOCK_PIN);
  // Strobe pulse
  delay_us(1);
  output_high(STROBE_PIN);
  delay_us(1);
  output_low(STROBE_PIN);
main()
  // Initialize outputs
  output_low(SROBE_PIN);
  write_braille(0x101);
  write_braille(0x102);
  write_braille(0x103);
    ; // loop forever
Christophe
PostPosted: Tue May 17, 2005 6:51 am     Reply with quote
heel erg bedankt! I'm sure I can use this.. The only thing is that I don't really know how to drive the cells :-s
The producer gives very few information
