muahaha95 Guest
where is the mistake? |
Posted: Thu Oct 13, 2005 2:19 pm |
hi all
my code is
#INCLUDE <18F452.H>
#CASE
#USE DELAY(CLOCK=16000000) //********************************* ! ! ! ! ! !
#FUSES HS,NOWDT,NOPROTECT,NOLVP
#DEFINE VER_MAJOR 0
#DEFINE VER_MINOR 01
#USE RS232(BAUD=19200,XMIT=PIN_E0,INVERT,STREAM=DEBUG)
#ZERO_RAM
#define use_PICDEM2_lcd TRUE
#if defined use_PICDEM2_lcd
#define lcd_en PIN_A1
#define lcd_rw PIN_A2
#define lcd_rs PIN_A3
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the second line
#define d_cycle 1
#endif
void lcd_send_nibble( BYTE n ) {
n=n&0x0f; //Strip off the top 4 bits.. This only sends bit 3:0
output_d(n);
delay_cycles(d_cycle);
output_high(lcd_en);
delay_us(20);
output_low(lcd_en);
BYTE lcd_read_byte() {
BYTE low,high;
output_high(lcd_rw);
high = input_d(); //using d0:d3 for 4 bit data bus
output_low(lcd_en);
delay_us(1);
low = input_d(); //using d0:d3 for 4 bit data bus
output_low(lcd_en);
return((high<<4) | low);
void lcd_send_byte( BYTE A0, BYTE n ) { //A0: 0=instruction, 1=Data
output_low(lcd_rs);
while ( bit_test(lcd_read_byte(),7) ) ; // wait until busy flag is low
if (A0==0){ output_low(lcd_rs);} //0=Instruction and 1=Data
if (A0==1){output_high(lcd_rs);} //0=Instruction and 1=Data
output_low(lcd_rw);
output_low(lcd_en);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init() {
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
// These bytes need to be sent to the LCD for initialization.
BYTE i;
//fprintf(debug,"Init!!\n\r");
output_low(lcd_rs);
output_low(lcd_rw);
output_low(lcd_en);
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i){
lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
BYTE Data;
if(y!=1)
Data=lcd_line_two;
Data=0;
Data+=x-1;
lcd_send_byte(0,0x80|Data);
void lcd_putc( char c) {
switch (c) {
case '\f' :
lcd_send_byte(0,1);
delay_ms(2);
case '\n' :
lcd_gotoxy(1,2);
case '\b' :
lcd_send_byte(0,0x10);
default :
lcd_send_byte(1,c);
char lcd_getc( BYTE x, BYTE y) {
char value;
lcd_gotoxy(x,y);
while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
value = lcd_read_byte();
output_low(lcd_rs);
return(value);
{ lcd_putc("savas");
lcd_putc();
but compuer said
Error[51] C:\savas\a.c 123 : A numeric expression must appear here
Halting build on first failed translation as user preferences indicate.
please help me |
Posted: Thu Oct 13, 2005 2:27 pm |
Quote: | Error[51] C:\savas\a.c 123 : A numeric expression must appear here |
Which line in your program is line 123 ? |
muahaha95 Guest
lcd_putc(); |
Posted: Thu Oct 13, 2005 2:29 pm |
lcd_putc(); |
Posted: Thu Oct 13, 2005 2:35 pm |
lcd_putc() requires a parameter.
Change your program to look like this:
Code: | void main(void)
lcd_putc("savas");
MUAHAHA95 Guest
THANK YOU PIC PROGRAMMER |
Posted: Thu Oct 13, 2005 2:39 pm |
THANKS |
muahaha95 Guest
to PIC PROGRAMMER |
Posted: Thu Oct 13, 2005 2:47 pm |
hEY MY Friend I ask a last question
I build the program but compuer said that
No Errors
BUILD FAILED: Thu Oct 13 23:44:52 2005
what is problem ? |
muahaha95 Guest
only led work |
Posted: Thu Oct 13, 2005 3:01 pm |
HEY MY FRIEND PROGRAM WORK BUT LCD DONT WORK ONLY LED WORK
WHAT DO YOU THINK ABOUT IT? |
Posted: Thu Oct 13, 2005 3:06 pm |
What board are you using to test the LCD ? Are you using a
Microchip PicDem2-Plus board, or something else ? |
muahaha95 Guest
About Board |
Posted: Thu Oct 13, 2005 3:08 pm |
I used PICDEM2 PLUS |
Posted: Thu Oct 13, 2005 3:32 pm |
That driver doesn't work. (sorry treitmey).
Use this one. It works. I tested it just now with a 18F452 on a PicDem2-
Plus board. It requires no changes. Just drop it in.
http://www.ccsinfo.com/forum/viewtopic.php?t=24661 |
MUAHAHA95 Guest
thanks |
Posted: Thu Oct 13, 2005 3:36 pm |
thanks for all things PIC PROG.... |
treitmey
Posted: Thu Oct 13, 2005 3:42 pm |
What doesn't work? Perhaps I should update the driver.
This little test worked.
#INCLUDE <18F452.H>
#CASE
#DEFINE VER_MAJOR 0
#ZERO_RAM
#include "picdem2.c"
int8 data;
//======================= MAIN ============================//
setup_adc_ports(NO_ANALOGS);
set_tris_a(0);set_tris_b(0);set_tris_c(0);set_tris_d(0);
fprintf(DEBUG,"STARTING CRI Test.\n\r");
fprintf(DEBUG,"FIRMWARE VERSION %u.%02u\n\r",VER_MAJOR,VER_MINOR);
printf(lcd_putc,"TEST");
while(TRUE){
Code: | ///////////////////////////////////////////////////////////////////////////
//// PICDEM2_LCD.C ////
//// Driver for common PICDEM2 PLUS LCD modules ////
//// lcd_init() Must be called before any other function. ////
//// lcd_putc(c) Will display c on the next position of the LCD. ////
//// The following have special meaning: ////
//// \f Clear display ////
//// \n Go to start of second line ////
//// \b Move back one position ////
//// lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1) ////
//// lcd_getc(x,y) Returns character at position x,y on LCD ////
#define d_cycle 1
#endif
output_d(n);
delay_us(20);
output_low(lcd_en);
BYTE low,high;
output_low(lcd_en);
delay_us(1);
output_low(lcd_en);
output_low(lcd_rs);
output_low(lcd_rw);
output_low(lcd_en);
void lcd_init() {
BYTE i;
output_low(lcd_rs);
output_low(lcd_rw);
output_low(lcd_en);
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i){
BYTE Data;
if(y!=1)
Data=lcd_line_two;
Data=0;
Data+=x-1;
switch (c) {
case '\f' :
lcd_send_byte(0,1);
delay_ms(2);
case '\n' :
lcd_gotoxy(1,2);
case '\b' :
default :
lcd_send_byte(1,c);
char value;
lcd_gotoxy(x,y);
output_low(lcd_rs);
return(value);
to PCM programmer Guest
about last code |
Posted: Thu Oct 13, 2005 3:45 pm |
Hey my friend
second program which you send only run led lamps but lcd is not work
I think main program is not enough
lcd_putc("savas");
what do you think about it? |
to TREITNEY Guest
about main |
Posted: Thu Oct 13, 2005 3:52 pm |
hey TREITNEY
thanks for main code
but still LCD doesnt work only led lamps work
I dont know where is the my mistake |
