moutinho
Strange!!! Does CCS project can?t have multiple .C files??? |
Posted: Thu May 12, 2005 12:22 pm |
I am trying to build a simple project composed by the following files:
Source Files
file01.c
main.c
Header Files
18F6720.h
def_hw.h
file01.h
file01.c:
// file1.c
#include "file01.h"
int sum(int a, int b)
return a + b;
main.c:
// main.c
#include "file01.h"
main()
int c = sum(1,1);
file01.h
//file01.h
#include "def_hw.h"
int sum(int, int);
I am having the following compiler error:
*** Error 70 "D:\Desenvolvimento Delfos\fonte\18F\Teste02\file01.c" Line 9(0,1): No MAIN() function found
If I place everything in only ONE .c file it works!!
Question: Can?t I have multiple .c files in one CSS project???????
Thanks in advance,
Andre Moutinho |
sseidman
Re: Strange!!! Does CSS project canīt have multiple .C files |
Posted: Thu May 12, 2005 12:37 pm |
moutinho wrote: |
Question: Canīt I have multiple .c files in one CSS project???????
Only by #INCLUDE-ing additional c files.
Scott |
Humberto
Posted: Thu May 12, 2005 2:45 pm |
CCS Cross Compiler doesnīt use a linker like TC Borland and others compilers does.
You can debug files individually, then must be listed as included files at the end of main.
The whole files format should follow this aproach:
//__________________________________
Header
#include <18F6720.h>
#include <def_hw.h>
#include <file01.h>
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,errors)
Defines Declarations
#define Buffer_Size 16
#define TRUE 1
#define Red_LED LATB.5
Global Variables Declarations
int8 a, b, c;
int16 d;
float e;
char x;
int8 Buffer_ZX[Buffer_Size];
Function Prepositions
long sum(int a, int b);
float mul(int a, int b);
Function Definitions
return (a + b);
M A I N
main()
a = 4;
b = 8;
d = sum(a,b);
e = mul(a,b);
Included Files
#include <file1.c>
#include <file2.c>
#include <file3.c>
file1.c Code: |
return (a * b);
Best wishes,
Humberto
NOTE: This is my own opinion/style, not a general rule. |
