how do I use the return of (-1)
mike holeton
PostPosted: Tue May 10, 2005 9:39 pm     Reply with quote
example code
char CompareName( char *OtherName )
char i;
for (i = 0; (i<J1939_DATA_LENGTH) && (OtherName[i] == CA_Name[i]); i++);
if (i == J1939_DATA_LENGTH)
return 0;
else if (CA_Name[i] < OtherName[i] )
return -1; //how do I do this?
return 1;
PostPosted: Wed May 11, 2005 3:13 am     Reply with quote
Key thing. A value has to be 'signed', to return a negative number. As written, a program at the other 'end', will 'see' 255'. A 'char' (and an integer), in CCS C, default to unsigned data types.
Basically, '-1', is coded in binary, as '11111111'. A character is an unsigned value, so the subroutine will return 255 (which is what the same binary value gives when treated as an unsigned number).
If you want to return a -1 'error' status, you have to change the declaration of the function, to:
signed char CompareName( char *OtherName )
Remember though that with a 'signed' declaration, the maximum value that can be returned, drops to 127.
Paolino
PostPosted: Wed May 11, 2005 3:14 am     Reply with quote
I have understood this: the statment
return -1;
has no effect in your code. Is it correct? If so, you have to declare differently the function and the variable returned. Infact, directly from CCS help on line
All types, except float, by default are unsigned; however, maybe preceded by unsigned or signed
Try this:
   char i;
   return 0;
   return -1; //Now it should work
   return 1;
If you prefer to keep the funciotn as is, you have to return a positive value, instead of -1.
