Dam Guest
| Timers not working properly |
Posted: Sun May 08, 2005 3:47 am |
Hello everybody,
I have a problem using the timers. I've tested the example file "EX_STWT2.C", but it counts too slowly (about 1/2 s / minute too slow). It seems that the timers begins to count again only when the interruption has been executed. (Nb: I have correctly adapted INTS_PER_SECOND; the problem is the same when using the other timers).
Do you know where's the problem ??
| Code: | #define INTS_PER_SECOND 125 // (20000000/(4*16*250*10))
int8 seconds; // A running seconds counter
int8 int_count; // Number of interrupts left before a second has elapsed
#INT_TIMER2 // This function is called every time
void clock_isr() { // timer 2 overflows (250->0), which is
// approximately 125 times per second for
if(--int_count==0) { // this program.
++seconds;
int_count = INTS_PER_SECOND;
setup_timer_2(T2_DIV_BY_16, 250, 10);
set_timer2(0);
while(TRUE) {
printf("Press any key to begin.\n\r");
getc();
seconds = 0;
printf("Press any key to stop.\n\r");
getc();
printf("%u seconds.\n\r", seconds);
Damn Guest
Posted: Sun May 08, 2005 4:09 am |
| Note: I tested it on a 16F876, and my compiler version is 3.205 |
Posted: Sun May 08, 2005 8:15 am |
One error is that the timers are already running before the user has pressed a key, worst case this will give you an offset error equalt to a single interrupt-time. In your case this equals 1/125 second error, not close to the error you have meassured.
I don't see any other obvious errors.
How are you meassuring the time? An error of 0,5 seconds is impossible to clock accurately on a stopwatch. Have you set up some automated testsystem using the serial port to a PC? If yes, then you'll have to correct for the delay introduced for transmitting all data over the serial port. What baudrate are you using? |
Posted: Sun May 08, 2005 9:01 am |
| To see the problem, I let it run a few minutes to see a noticeable difference. I did the test a few times the problem was always there. |
Posted: Sun May 08, 2005 12:58 pm |
| Anonymous wrote: | | To see the problem, I let it run a few minutes to see a noticeable difference. I did the test a few times the problem was always there. | You didn't answer my questions.
I suspect the way you meassure the time is introducing some 'overhead'.
For example, running the test several times also incorporates the time of transmitting the display texts over RS232. I don't know your baudrate, but at 9600baud the given texts will take almost 0,1 sec. Then you'll have to add to this the turn-around-time of your PC Operating system, I remember an old Windows version where this was default set to a few hundred miliseconds (configurable). All these additional delays could be the cause of your 0.5sec timing offset.
Like I said before, the program looks fine. Without you giving more details on how you took your meassurements I'm not going to invest time in searching for a bug that's likely not there. |
Dam Guest
Posted: Sun May 08, 2005 1:50 pm |
Yes, I understand.
I simply ran the code, hit a key, then wait 8 minutes, then hit another key, and saw the result. I measured the time with the pc clock, and there was (at each test) 4 seconds more than what the PIC told me.
I've tested to make the interrupt code longer: the time difference was yet greater. So it seems that the timer only counts again when the interrupt code has been executed. I'm not a PIC specialist so I can't analyse the ASM code.
This problem really bothers me . Thanks for your help  |
Posted: Sun May 08, 2005 4:30 pm |
The timer runs in the interrupt.
Look carefully at your count values. Realise that the timer counts to 250, and then resets to zero on the _next_ increment. The timer values you are using, will actually run 251/250 'slow'. Should be two seconds, not four seconds, in eight minutes, but this is probably the starting point for the error.
Dam Guest
Posted: Tue May 10, 2005 3:19 am |
Ckielstra, do you also think that the problem could come from that ?
Anyway I'm disappointed that this code, provided as example by CCS, doesn't work properly. |
Posted: Tue May 10, 2005 8:20 am |
Historically the 'wizard', calculated the wrong values for many times, for a lot of CCS versions, so I'd suspect the timings, were set up by the wizard, which happened to be faulty at that point, and this has never been corrected...
