how to connect GPS module to CCS 18F8720 proto broad
tranjimmysd
PostPosted: Thu May 05, 2005 3:32 pm     Reply with quote
I just purchased a CCS 18F8720 proto board. Now I want to connect a GPS module with the one of UART/232 ports of the 18F8720.
The problem I have is the Votage level is not compatible.
My GPS module UART has voltage level 3.3 volt.
The PIC UART is around 5.0 volt. Please help me how to connect the two together without burning any thing :-)
Thank you
PostPosted: Fri May 06, 2005 12:08 am     Reply with quote
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=22334
Jimmytransd
PostPosted: Mon May 09, 2005 11:57 am     Reply with quote
thank you so much. You are truly the great helper
