Reserving a fixed memory location for serial numbering.
h.a.j.molenaar
PostPosted: Wed May 04, 2005 8:40 am     Reply with quote
Hi all. I want to use a serial number which must be read by the firmware itself. My programmer (BeeProg) can insert an incremental number in the program memory.
I want to do like this (PIC12F683).
unsigned long int const value = 0x0000;
I want this on a fixed memory location, preferably at the end of the map.
This is at 07FD.
How do I do this or is there a more better way?
Thanks, Hugo
Haplo
PostPosted: Wed May 04, 2005 9:25 am     Reply with quote
From the manual:
#ROM
Syntax:
#rom address = {list};
Elements:
address is a ROM word address, list is a list of words separated by commas
Purpose:
Allows the insertion of data into the .HEX file. In particular, this may be used to program the '84 data EEPROM, as shown in the following example.
Note that this directive does not prevent the ROM area from being used. See #ORG to reserve ROM.
Examples:
#rom 0x2100={1,2,3,4,5,6,7,8}
Example Files:
None
Also See:
#org
#ORG
Syntax:
#org start, end
or
#org segment
or
#org start, end {}
or
#org start, end auto=0
#ORG start,end DEFAULT
or
#ORG DEFAULT
Elements:
start is the first ROM location (word address) to use, end is the last ROM location, segment is the start ROM location from a previous #org
Purpose:
This directive will fix the following function or constant declaration into a specific ROM area. End may be omitted if a segment was previously defined if you only want to add another function to the segment.
Follow the ORG with a {} to only reserve the area with nothing inserted by the compiler.
The RAM for a ORG'ed function may be reset to low memory so the local variables and scratch variables are placed in low memory. This should only be used if the ORG'ed function will not return to the caller. The RAM used will overlap the RAM of the main program. Add a AUTO=0 at the end of the #ORG line.
If the keyword DEFAULT is used then this address range is used for all functions user and compiler generated from this point in the file until a #ORG DEFAULT is encountered (no address range). If a compiler function is called from the generated code while DEFAULT is in effect the compiler generates a new version of the function within the specified address range.
Examples:
#ORG 0x1E00, 0x1FFF
MyFunc() {
//This function located at 1E00
#ORG 0x1E00
Anotherfunc(){
// This will be somewhere 1E00-1F00
#ORG 0x800, 0x820 {}
//Nothing will be at 800-820
#ORG 0x1C00, 0x1C0F
CHAR CONST ID[10}= {"123456789"};
//This ID will be at 1C00
//Note some extra code will
//proceed the 123456789
#ORG 0x1F00, 0x1FF0
Void loader (){
Example Files:
loader.c
Also See:
#ROM
PostPosted: Wed May 04, 2005 10:17 am     Reply with quote
Another poster has already given you details of how to reserve a location, and write something at it.
Unfortunately, you cannot access this like a const variable though. The problem is that when you declare a const variable, the compiler actually inserts a 'header', which then allows the data to be read, in front of the data. A const variable uses significantly more memory, than the actual size of the value to be stored. the nature of this, depends on the chip involved (more latter...)
So you can declare a block of memory at a location, using #ROM, like:
#ROM 0x7FD = {12,34,56,78}
Four bytes will be stored at 0x7FD. However to access it, you will need to use the 'read_program_memory' function to read the data.
There are some 'caveats' though. On a 18chip, ROM stores 16bit values at each location. On smaller chips the size of each value is limited by the chip. The read function similarly only returns whatever data size actually exists at the location.
The big problem for you, is that the read function requires a chip that supports direct reading of the program memory using the registers for internal flash programming. Your chip does not support this. On chips without this ability, a 'const', is stored using the upper part of each instruction, combined with a 'RETLW' instruction. So when you declare a four byte constant, these values are not directly stored in the chip. Instead three instructions set the bank registers, then the offset of the required byte is added to the PC, to trigger a jump to the required return instruction, and the values are stored as a 'table' of RETLW instructions in the next few bytes. The instruction, then returns to the caller, with the required value. This means that you can only store byte values that contain the RETLW instruction. If a programmer changed one of these into another instruction, the code will fail...
So, though your programmer can insert an incremental number into program memory, this feature is not useable with the chip you have!. However there is one possibility. If your programmer can insert the value at the addresses for the internal EEPROM (0x2100 to 0x21FF), this is accessible by the read_program_eeprom instruction.
PostPosted: Wed May 04, 2005 11:45 am     Reply with quote
You mean the read_eeprom() function.
PostPosted: Wed May 04, 2005 3:15 pm     Reply with quote
Yes.
Slip of the keyboard.
h.a.j.molenaar
PostPosted: Sun May 08, 2005 11:44 pm     Reply with quote
I like to thank the contributors for their response.
