If so is there any way you could skip from one bit of code to another?
I wanted to jump back to a point in a while loop from a function that is called from within the loop:
while
label:
function;
function()
goto label;
Obvoiusly this does not work, is there a way of doing this??
Thanks.
Posted: Thu May 19, 2005 8:26 pm
Here are some examples of doing it by normal methods:
// This method uses a goto statement.
char c;
while
c = 0x55;
label:
result = function();
if(result == ERROR_CODE_5)
goto label;
function()
return(ERROR_CODE_5);
This method uses an inner while() loop and the continue statement.
char c;
while
c = 0x55;
continue; // Go to the start of the inner while() loop
function()
Chubbs
Posted: Thu May 19, 2005 11:18 pm
Thanks once again, I was able to successfully use it in my program.
