Barry Gershenfeld Guest
| Set ICD-2 "Background Debug" in MPLAB6 |
Posted: Fri Feb 14, 2003 6:26 pm |
I have discovered in MPLAB 6 that if you set the fuses in your source, the Configuration for the PIC (PUT, BOR, WDT, etc) will be set accordingly in the ICD-2.
But in some circumstances the Background Debug (that's the "load the debug monitor" feature) keeps going back to Disabled and I can't figure out the source of that setting. I have tried "device ICD=TRUE" but that's not it. Anyone?
Barry
___________________________
Original Post ID: 11718 |
john cutler
Joined: 06 Sep 2003 Posts: 82 Location: Hot Tub, California
| Re: Set ICD-2 "Background Debug" in MPLAB6 |
Posted: Fri Feb 14, 2003 9:24 pm |
I don't have an ICD-2, but in MPLAB6.10 in "build options" under "Project" - there's a tab for CCS Compiler and on that page a check box there for "compile for ICD"
Maybe that will do it for you?
John
:=I have discovered in MPLAB 6 that if you set the fuses in your source, the Configuration for the PIC (PUT, BOR, WDT, etc) will be set accordingly in the ICD-2.
:=But in some circumstances the Background Debug (that's the "load the debug monitor" feature) keeps going back to Disabled and I can't figure out the source of that setting. I have tried "device ICD=TRUE" but that's not it. Anyone?
:=Barry
Original Post ID: 11721 |
poulholmoethomsen Guest
Posted: Mon Feb 17, 2003 8:16 am |
:=Barry
It is my experience that if you enable 'Background' Debug, the ICD2 will not waork at all.
So just leave it disabled.
Regards
Poul
Original Post ID: 11786 |
| Re: Set ICD-2 "Background Debug" in MPLAB6 -- OK |
Posted: Mon Feb 17, 2003 3:50 pm |
:=I don't have an ICD-2, but in MPLAB6.10 in "build options" under "Project" - there's a tab for CCS Compiler and on that page a check box there for "compile for ICD"
:=Maybe that will do it for you?
:=John
Thanks, John, that seems to be the lead I needed. So many options...Digging deeper, there is a Debugger-level setting, a Project-level setting, as well as the "ICD=TRUE" directive I can put in the code. In some of my projects the debugger is on by default, but in this one is was off. "Checking the box" got it to default to "on". I'll figure out all the combinations eventually; I'm patient...
Poul:
When the Background Debug is disabled, it prompts to see if I want to enable it (that's how I know when it's off). My ICD2 does work, so there is hope for yours. Perhaps we could help you somehow.
Barry
Original Post ID: 11813 |
Freddie L Guest
Posted: Wed Feb 26, 2003 9:46 am |
What fuses do you set in the code when using the ICD?
For the 16F877, CCS PCM does not have a #fuse option for Debugging ON?
:=Barry
Original Post ID: 12120 |
