Compile Error when using Malloc
sambuddy
PostPosted: Sat Apr 30, 2005 5:38 pm     Reply with quote
Hello All,
I am porting some code over to CCS from an AVR platform. I have found that when I port the code over using malloc
<SNIP>
rp = malloc((sizeof(FILE)));
<SNIP>
I get the following compile error
<SNIP>
*** Error 132 "C:\PROGRA~1\PICC\drivers\memmgmt.c" Line 65(34,35): STDOUT not defined (may be missing #USE RS232) In call_1 ??65535
<SNIP>
I do have a "#USE RS232" in my main header file, so I'm not sure whyit is complaining.
Any suggestions would be greatly appreciated
Regards
Sambuddy
PostPosted: Sat Apr 30, 2005 11:19 pm     Reply with quote
There's a function in memmgmt.c, called "print_list()". It has some
printf() statements in it, and that's what's causing your problem.
It looks to me as if CCS was using this function to debug their
routines and accidently left it in there. It's not called by any other
memory management functions. You can just comment it out.
densimitre
PostPosted: Sun May 01, 2005 8:48 pm     Reply with quote
Hi
From help:
malloc(); Requires STDLIBM.H must be included
