| #asm i can't compile asm part |
Posted: Tue Apr 26, 2005 2:14 pm |
i get this code form http://www.ccsinfo.com/forum/viewtopic.php?t=17170&
i cant compile asm part. compiler highlights comma shown in red below, and says "expecting an identifier".
on first asm line:
MOVF DATA , W //copy pointer to first
i'm trying on pic18f452. DVDB says it working, but i can't do it.
i need help. thanks.
int calc_CRC(int* data,int byte_cntr)
int crc=0;
#ASM
MOVF DATA , W //copy pointer to first databyte..
MOVWF FSR //..to pointer register
loop:
MOVF INDF,W //load w with next databyte
xorwf crc,f // xor with accumulated crc (accumulated crc is no longer valid now)
movlw 0 //w will ccumulate the new crc
btfsc crc,0
xorlw 0x5e //could also be iorlw
btfsc crc,1
xorlw 0xbc
btfsc crc,2
xorlw 0x61
btfsc crc,3
xorlw 0xc2
btfsc crc,4
xorlw 0x9d
btfsc crc,5
xorlw 0x23
btfsc crc,6
xorlw 0x46
btfsc crc,7
xorlw 0x8c
movwf crc //store accumulated crc
INCF FSR //increment indirection register to point to next databyte
decfsz byte_cntr,F
goto loop //next databyte
//done, crc is in w
movwf crc //store in result
#ENDASM
return(crc);
| [url][/url] |
Posted: Tue Apr 26, 2005 2:16 pm |
i forgot to say, i tested with data, DATA (lowercase, uppercase)
still same. |
Posted: Tue Apr 26, 2005 2:24 pm |
I made a full test program, and added definitions for your FSR and INDF
symbols, and it then compiled OK with PCM vs. 3.224.
| Code: | #include <16F877.H>
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#define FSR 4
#define INDF 0
int calc_CRC(int* data, int byte_cntr);
char array[10];
char count;
calc_CRC(array, count);
int crc=0;
#ASM
loop:
xorwf crc,f // xor with acc'd crc (acc'd crc is no longer valid now)
btfsc crc,0
btfsc crc,1
xorlw 0xbc
btfsc crc,2
xorlw 0x61
btfsc crc,3
xorlw 0xc2
btfsc crc,4
xorlw 0x9d
btfsc crc,5
xorlw 0x23
btfsc crc,6
xorlw 0x46
btfsc crc,7
xorlw 0x8c
INCF FSR //inc. indirection reg to point to next databyte
decfsz byte_cntr,F
//done, crc is in w
#ENDASM
return(crc);
Posted: Wed Apr 27, 2005 3:40 pm |
i copied, and pasted code posted by PCM programmer, compiled well.
but i switched to 18f452, no luck. still same problem.
test code here:
//#include <16F877.H>
//#fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
//#use delay(clock=4000000)
#include <18F452.h>
#fuses XT, NOWDT,NOPROTECT, NOLVP, NOPROTECT, PUT
#define FSR 4 //not for 18f452.
#define INDF 0 //i want to compile only. dont worry about these.
char array[10];
char count;
int calc_CRC(int* DATA, int byte_cntr)
int crc=0;
#ASM
loop:
btfsc crc,0
btfsc crc,1
xorlw 0xbc
btfsc crc,2
xorlw 0x61
btfsc crc,3
xorlw 0xc2
btfsc crc,4
xorlw 0x9d
btfsc crc,5
xorlw 0x23
btfsc crc,6
xorlw 0x46
btfsc crc,7
xorlw 0x8c
decfsz byte_cntr,F
//done, crc is in w
#ENDASM
return(crc);
Posted: Wed Apr 27, 2005 4:28 pm |
I think that DATA may be a keyword, because if you change it to DATA1
(in all instances), then it compiles OK. |
Posted: Wed Apr 27, 2005 5:22 pm |
Thanks a lot, PCM programmer.
I can't believe, it worked... why 'data' causes this problem? i searched help file for "reserved' words, i didn't find anything. maybe i may look asm side. target device=16f877 no problem, target device=18f452 compile error, i didn't understand anything. this may be my homework.
In this case i think CCS must change their help file.
this lines coming from help file. topic: #ASM. this example also uses 'data' as parameter name.
int find_parity (int data) {
int count;
#asm
movlw 0x8
movwf count
movlw 0
loop:
xorwf data,w
rrf data,f
decfsz count,f
goto loop
movwf _return_
#endasm
i copied and pasted same problem at 'xorwf data,w' with 18f452. if you select device=16f877 compiles succesfully...
hayri |
